Does flashing enable WH14NS40 to play UHD/4K discs?
joeybuddy96
#1 Post by joeybuddy96 » Sun May 30, 2021 12:08 am
I already have a WH14NS40. I don't really do any ripping at all. I would just rather not plop a Benjamin down on a new drive just to get 4K/UHD support.
Re: Does flashing enable WH14NS40 to play UHD/4K discs?
#2 Post by Woodstock » Sun May 30, 2021 1:41 am
Run MakeMKV. What does it say about your drive?
And, if you're not ripping, why do you worry about UHD support?
#3 Post by MartyMcNuts » Sun May 30, 2021 2:21 am
If your drive is UHD ripping capable and LibreDrive enabled, you can use MakeMKV as an "on-the-fly" decryption engine and watch your UHD discs directly.
joeybuddy96
#4 Post by joeybuddy96 » Mon May 11, 2026 12:06 am
Woodstock wrote: Sun May 30, 2021 1:41 am Run MakeMKV. What does it say about your drive?
Product: BD-RE WH14NS40
Revision: 1.01
Serial number: K9ED9AE1114
Firmware date: 2113-04-04 23:25
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
At the time, I wanted to just be able to play UHD discs and not rip them. Intel shut down the server that allowed UHD playback last year (https://community.intel.com/t5/Intel-So ... -p/1545831), so ripping is pretty much required to watch UHD blu-rays, even if I buy a drive that is physically capable of UHD blu-ray playback.
#5 Post by Woodstock » Mon May 11, 2026 1:10 am
Your drive was built over two years before UHD support was added to LG drives, and your hardware will not support it (MT1939 processor).
joeybuddy96
#6 Post by joeybuddy96 » Mon May 11, 2026 4:15 pm
Ah, thanks for researching that!
Is there something I need to do to at least be able to rip regular blu-rays? Do I need to buy certain firmware or a flashing utility, and a MakeMKV license?
#7 Post by Woodstock » Mon May 11, 2026 6:11 pm
As far as ripping non-UHD disks, it should work fine. Normal Bluray is what that chip was designed for.
It will work with normal playing software and MakeMKV just fine. I used to have a couple of them before my equipment was stolen last year.
