Chaos Walking (NA) (Best Buy) - Here is the correct segment map
archer
Post by archer » Tue May 25, 2021 7:26 am
Another UHD with a lot of playlist obfuscation, the correct segment map is:
505,500,502,503,504,501,509
Balthazar2k4
Re: Chaos Walking (NA) (Best Buy) - Here is the correct segment map
Post by Balthazar2k4 » Tue May 25, 2021 5:08 pm
Awesome! Thanks!
avenger09123
Post by avenger09123 » Wed May 26, 2021 12:48 am
0523.mpls has those.
MSDowney
Post by MSDowney » Thu May 27, 2021 1:55 pm
Does anyone have it for Redbox? The Redbox version doesn't even have the 500 segment :)
Post by dcoke22 » Thu May 27, 2021 2:16 pm
Has Redbox started renting UHDs? If it just a regular blu-ray… viewtopic.php?f=8&t=25352
jayper
Post by jayper » Thu May 27, 2021 2:38 pm
Red Box does rent UHDs.
bmillham
Post by bmillham » Fri May 28, 2021 6:38 am
This is also the correct map for the version that I purchased at Walmart. Thanks!
eNoize
Post by eNoize » Mon May 31, 2021 8:42 pm
Thank you, good sir!
On my UHD, the correct playlist is the 00523.mpls file
stephon1024
Post by stephon1024 » Thu Jun 03, 2021 9:48 pm
Awesome thanks so much! Picked up the RedBox and it had a different segment map than the 10 segment one posted, but it looks like it's 523.mpls for all versions regardless. Mine matched up perfectly with your data!
Mr_Movie_Dog
Post by Mr_Movie_Dog » Sat Jun 05, 2021 3:27 pm
Red Box does rent 4K UHD's just a limited selection of them. The correct segment map for the Rentals is the same as the Retail in the US.
Title information
Name: Chaos Walking (English)
Source file name: 00523.mpls
Duration: 1:48:54
Chapters count: 16
Segment count: 1
Segment map: (505,500,502,503,504,501,509)
File name: Chaos Walking_t92.mkv
00505.mt2s    00:27.08 (15.5 GB)
00500.mt2s    00:00:21 ( 211 MB)
00502.mt2s    00:00:57 ( 595 MB)
00503.mt2s    00:00:33 ( 341 MB)
00504.mt2s    00:01:01 ( 479 MB)
00501.mt2s    00:00:25 ( 259 MB)
00509.mt2s    01:18:26 (41.5 GB)
