MP4 DV movies with FEL are playing very dark on my CX also (and other users reported the same in this thread if i remember correctly).Donpablo80 wrote: ↑Sun May 02, 2021 7:27 amRecently I bought the 65 inch LG Oled CX. I have a lot of MP4 Dolby vision movies that play fine on my older Oled B7, but they are not whatchble on my CX, they look very dark. Is this a known problem?
EDIT:
I see it's a known problem. Anything to do about it? Or just download the hdr10 version of the movie.
Titles with MEL are playing fine though and therefore unfortunately the only solution i found, was to convert the FEL to MEL (but probably any way discarding the extra data for reconstructing the original 12-bit signal and only keeping the RPU should be sufficient).
I think MakeMKV is showing if EL is Full or Minimal, or just check e.g. here: https://forum.blu-ray.com/showthread.php?t=276448
For messing around with ELs/RPU best experience for me was with quietvoid's tool: https://github.com/quietvoid/dovi_tool (thanks very much for your effort from a mostly only reading user on this way
