Re: SDFtool Flasher
Post by MartyMcNuts » Tue May 11, 2021 1:02 am
impeeza wrote: Mon May 10, 2021 4:29 am
MartyMcNuts wrote: Fri Feb 12, 2021 12:02 am The tar file does not contain the complete fw from your drive. It only contains the important fragments, making it possible to create a complete fw file by using another fw file and replacing those important sections.
The tar file cannot be used for recovery.
Did you even read the instructions?? Please don't listen to brucehvn. I know he is trying to help you but he has no idea what he is talking about.
Regarding your issue,
When you say you updated the drive to 1.05, did you mean the official 1.05 via LG's website? or the MakeMKV 1.05-MK firmware?
If you updated via the official LG 1.05 flashing tool, you must flash the drive to a MK firmware (I recommend WH16NS60 1.02-MK) then flash to a DE firmware (I recommend DE WH16NS60 1.00), then use the old DOSFLASH method to recover your drive.
Read here: https://www.makemkv.com/forum/viewtopic ... 15#p104021
Hi now time for the very noob question :D :
when you use the «READ Firmware» option, you get a Tar file, ok, there is any guide to create a correct firmware file to be restored to drive using the bin files on it? thanks for you time.
The read function is generally not required as you can just flash the original firmware back to the drive using the vendor's original flasher (from the link I gave you previously). The important bits are not overwritten.
Freaky69
Re: SDFtool Flasher
Post by Freaky69 » Wed May 19, 2021 10:08 am
Hello all,
so if I'm read it correctly i can buy a BU40N Slimeline Drive and use your SDFtool Flasher with your DE_LG_BU40N_1.00 firmware and tickle the enc? Box?
No need to use the cmd script provided by Billy?
Re: SDFtool Flasher
Post by MartyMcNuts » Wed May 19, 2021 11:09 am
Freaky69 wrote: Wed May 19, 2021 10:08 am Hello all,
It's essentially the same thing, just in a GUI.
Seantik
Re: SDFtool Flasher
Post by Seantik » Sat May 22, 2021 11:24 pm
Do I need o do anything or is the job done?
I've just flashed my BU40N with the newest MK firmware BIN file from the BU40N-N-Main folder. Everything went fine and it said 100% succes. Aftwerwards I checked with MakeMKV and saw iI was still on firmware 1.04.....
OS drevnavn: K:
Producent: HL-DT-ST
Produkt: BD-RE BU40N
Version: 1.04
Serienummer: xxxxxxxx
Firmware dato: 2120-05-06 11:42
Krypteringsflag for databuss: 17
Highest AACS version: 76
Firmware version: 1.04
Am I able to rip now or do I need to downgrade any further? In case I need to flash again please tell which BIN I need to use and what to be aware of. I.e. can I gro directly to a 1.00? should it be DE or MK?
Mr_Orange
Re: SDFtool Flasher
Post by Mr_Orange » Sat May 22, 2021 11:40 pm
Looks good. Just go ahead and test a disc.
Re: SDFtool Flasher
Post by MartyMcNuts » Sun May 23, 2021 2:45 am
Seantik wrote: Sat May 22, 2021 11:24 pm Do I need o do anything or is the job done?
OS drevnavn: K:
Producent: HL-DT-ST
Version: 1.04
You could stay o 1.04-MK (but I don't recommend it) or you can now flash to DE BU40N 1.00.
Seantik
Re: SDFtool Flasher
Post by Seantik » Sun May 23, 2021 7:48 am
Excellent - TY.
Forgive me for asking but why is it recommended not to stay with 1.04MK?
However I will follow your advice MartyMcNuts, and flash to DE 1.00. Just to be sure so I won't brick my drive. Please confirm that I can flash from 1.04MK to DE 1.00 using SDFtool flasher and when I do that, I will not mark "enc" as my drive is no longer encrypted?
Re: SDFtool Flasher
Post by MartyMcNuts » Mon May 24, 2021 6:24 am
Seantik wrote: Sun May 23, 2021 7:48 am Excellent - TY.
1.04 is simply not a very good firmware.
Yes, correct.
hkaspy
Re: SDFtool Flasher
Post by hkaspy » Mon May 31, 2021 4:22 pm
Thank you MartyMcNuts for this awesome utility!
Can confirm successfull flash of LG BH16NS55, 2021 version to WH16NS60 1.02MK.
HL-DT-ST_BD-RE_BH16NS55_1.05_212006181342
ToadTheMagic Dragon
Re: SDFtool Flasher
Post by ToadTheMagic Dragon » Sat Jun 05, 2021 8:19 pm
FlyByWire1 wrote: Fri Apr 09, 2021 9:35 pm Hi there,
I own a MATSHITA BD-MLT UJ272 S 1.00 (Labels as TechPulse 120). Doing some research, but got confusing information. I read it is a Panasonic, or Pioneer device. Otherwise, it's said it is an LG BU40N. Anyways, I would like to get it UHD friendly if possible. Right now it's only BD capable. Would it be possible to unlock UHD function by flashing the firmware?
I already tried to use the flasher from this thread viewtopic.php?f=16&t=18873#p70284, but it did not work, cause the flasher doesn't recognize the drive (probably due to the controller in the external housing). The SDFtool Flasher, at least, recognized the drive, so I thought this might be working?
Which fw would be correct. I'm overwhelmed with all the different information, sorry for asking.
I had a similar problem flashing my BP60NB10 with SDFtool Flasher v1.2.0. It would not recognize my drive. However, if I had MakeMKV running (v1.16.3 x64) then the drive was recognized and I could select the MK firmware (mk-firmware-pack-20200720) and perform the flash successfully.
Don't know if this is a requirement for SDFtool Flasher (I'd not seen this mentioned) or there is some other anomaly but I thought I'd post just in case others are seeing the same issue when attempting to use SDFtool Flasher.
Best ...
"Once Upon a Time ... there was a Magic Dragon named Toad"
in a land far far away
SteelBookCollector
Re: SDFtool Flasher
Post by SteelBookCollector » Fri Aug 20, 2021 1:47 pm
Got a brand new WH16NS40 with 1.05 Firmware.
SDFTool v1.2.0, trying to flash to WH16NS60 v1.02 from the old folder, check the enc box.
Getting error code 0x8f056103
On Windows 10 X64. dotNet newer then 4.7.2
What am I doing wrong?
Screen Shot 2021-08-20 at 9.38.39 AM.png (876.77 KiB) Viewed 36586 times
Re: SDFtool Flasher
Post by Coopervid » Fri Aug 20, 2021 10:11 pm
First flash 1.05 MK with enc. Then downgrade to whatever you want.
After that don't check enc anymore.
Re: SDFtool Flasher
Post by Billycar11 » Sat Aug 21, 2021 12:41 am
SteelBookCollector wrote: Fri Aug 20, 2021 1:47 pm Got a brand new WH16NS40 with 1.05 Firmware.
that should have worked try the command line.
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Aug 21, 2021 1:14 am
How is your drive connected?
Do you have MakeMKV 1.15.1 or above instlled?
joitronix
Re: SDFtool Flasher
Post by joitronix » Sun Aug 22, 2021 3:56 am
MartyMcNuts wrote: Sat Aug 21, 2021 1:14 am
Hi, thnk for your job, i'm a very big jackie chan fan, and i want to transfer them to my pc, seems the ps3 cant read uhd dics.... after investigating too much y found your post and i found a "cheaper" reader that is in your list:https://www.amazon.es/Asus-BC-12D2HT-Bl ... 00F0SQLR8/
Y see in your folder have the same name but i have some questions:
I not see in the list that this hard drive come with encrypted so i not need to mark it in the tool?.
Some people say i need to put sata on ide is necessary with your tool?
Is that easy than select the bin file and select the drive and press write or i need to check something before?
THNK YOU VERY MUCH.
