tophee
#1
Post
by tophee » Sat Feb 05, 2011 7:49 pm
Hi
I'm having issues ripping this disc. I've had a go at searching the forum, but can't see anyone else having difficulties with this title. I'm getting these errors reported:
Saving 1 titles into directory /home/chris/Videos/AstroBoy
DEBUG: Code 0 at UwK&#[Rz49sdU4:29398967
DEBUG: Code 0 at 0XV.|[W~,M`/sg+id$*%:29397518
DEBUG: Code 0 at hROJ4/#{6&Lf" +g#C:QK:29397449
DEBUG: Code 0 at wj>L`%VT!af')jmvqDn:121263751
Failed to save title 0 to file /home/chris/Videos/AstroBoy/title00.mkv
0 titles saved, 1 failed
Is it likely to be the disc itself? I can't see any marks or or defects on the disc itself, though that's only my naked eye. What are these error codes telling me?
Post
by mike admin » Sun Feb 06, 2011 10:44 am
The log indicates a corrupted video stream. Can you try making a full disc backup first and see if any errors show up?
tophee
#3
Post
by tophee » Sun Feb 06, 2011 2:40 pm
HI Mike,
If you mean by "full disc backup first" I rip everything off the disc using makemkv - done that. Still throws a hissy fit at the same place.
If you mean something else, could you elaborate?
Many thanks
Chris
-edit-
Doh. I see what you mean now. Am in process of backing up "as is"
tophee
#4
Post
by tophee » Sun Feb 06, 2011 10:28 pm
Right, I've managed to successfully backup the disk twice - once with and once without protection.
I tried to run makemkv on the backup with protection and it failed.
I'm next going to run makemkv on the protection removed backup. I'll let you know how that goes.
tophee
#5
Post
by tophee » Mon Feb 07, 2011 9:42 pm
Well, still didn't work. The with and without protection backups both fail with the same error code.
This came from the backup without protection.
A bad disk?
Oh and from the debug log:
001003:0020 DEBUG: Code 0 at UwK&#[Rz49sdU4:29398967
001003:0020 DEBUG: Code 0 at 0XV.|[W~,M`/sg+id$*%:29397518
SEI=PAAABBgEEAAaDAIGA
001003:0020 DEBUG: Code 0 at hROJ4/#{6&Lf" +g#C:QK:29397449
001003:0020 DEBUG: Code 0 at wj>L`%VT!af')jmvqDn:121263751
FS ID=<FAILED> C=0
TI=ZeNpjZBhYAAABAAAC
Post
by mike admin » Tue Feb 08, 2011 10:13 am
The video stream on disc is corrupted, but the disc has no physical defects. It means that this disc has a mastering error. Please provide exact title and region for this disc.
tophee
#7
Post
by tophee » Wed Feb 09, 2011 9:01 pm
Hi Mike,
It's the UK release of AstroBoy and it was on BluRay a disc, which is Region B I believe.
I "borrowed" it from a friend and have now returned it, so can't help much beyond that, so if you wanted any further information I've got the backups.
HTH
setarip_old
#8
Post
by setarip_old » Thu Feb 10, 2011 5:04 am
@tophee
Is the disc you borrowed from your friend an original, commercial Blu-ray disc or a backup copy?
tophee
#9
Post
by tophee » Thu Feb 10, 2011 10:15 am
It was a commercial, original blu-ray disc. Though I now have an unencrypted and encrypted backup.
moamoa
#10
Post
by moamoa » Fri Mar 04, 2011 1:06 am
I have the very same problem on Astro Boy.
I don't think it can be a faulty disk, it must be an issue with MakeMKV ?
Post
by mike admin » Fri Mar 04, 2011 11:11 am
moamoa wrote:Hi,
Please reproduce the problem with 1.6.5 and debug log enabled, and then send the FULL debug log file to
support@makemkv.com . A lot of debug output was added to 1.6.5 specifically to catch this problem.
