MKV files or Oppo udp 203 issue?
ghost rider
Earlier this year I posted about issues I was having with audio syncing or drop outs with my new UHD movies. Star wars saga and LOR's movies.
I don't use it much and today I played a movie I know was good a couple years ago and it does it too. I played the original disc and seems to play fine.
I'm going to play some BD files and see how they work.
ghost rider
Re: MKV files or Oppo udp 203 issue?
Plays BD files perfect.
Titles using "seamless branching" combined with DolbyTrueHD audio will rip with glitches at the branch points. The Oppo player stumbles on those. None of the MKV ripping tools have fixed this issue for UHD discs, so for those titles (mainly Disney), you should rip to BDMV folder and play that on the Oppo - problem solved.
ghost rider
How can I do this? Rip the movie using anydvd? Is there another tool that I can rip a movie only BD file?rdgrimes wrote: Fri May 21, 2021 2:30 am Titles using "seamless branching" combined with DolbyTrueHD audio will rip with glitches at the branch points. The Oppo player stumbles on those. None of the MKV ripping tools have fixed this issue for UHD discs, so for those titles (mainly Disney), you should rip to BDMV folder and play that on the Oppo - problem solved.
Just use makemkv and do a folder backup. Also make sure you check the decrypt folder option.ghost rider wrote: Sat May 22, 2021 3:21 amHow can I do this? Rip the movie using anydvd? Is there another tool that I can rip a movie only BD file?rdgrimes wrote: Fri May 21, 2021 2:30 am Titles using "seamless branching" combined with DolbyTrueHD audio will rip with glitches at the branch points. The Oppo player stumbles on those. None of the MKV ripping tools have fixed this issue for UHD discs, so for those titles (mainly Disney), you should rip to BDMV folder and play that on the Oppo - problem solved.
are these new rips with the latest version of makemkv? im pretty sure this was fixed a few versions ago but you will need to re rip if it was before the fixghost rider wrote: Sat May 22, 2021 3:21 amHow can I do this? Rip the movie using anydvd? Is there another tool that I can rip a movie only BD file?rdgrimes wrote: Fri May 21, 2021 2:30 am Titles using "seamless branching" combined with DolbyTrueHD audio will rip with glitches at the branch points. The Oppo player stumbles on those. None of the MKV ripping tools have fixed this issue for UHD discs, so for those titles (mainly Disney), you should rip to BDMV folder and play that on the Oppo - problem solved.
Some tools claim to have fixed it for UHD, but its only fixed for SOME players. The Oppos still see the glitches and randomly drop out.Billycar11 wrote: Sat May 22, 2021 3:26 am are these new rips with the latest version of makemkv? im pretty sure this was fixed a few versions ago but you will need to re rip if it was before the fix
I am able to play BMDV files using oppo JB without any issues. But it does not show the thumbnail of the movies, rather I need to go through a list. I tried using DVDFab with my LG drive to convert it to MP4 in one go instead of create a backup first and then create MP4, but DVDFab says that my disk is not compatible with it, it has to change my firmware, where as the firmware has already been changed using this forum and it’s working with MakeMKV.
Are there any good solutions to make the backup in BMDV and then add thumbnails?
OR
Create another format in one pass, I don’t want to create BMDV and then convert to MP4 etc? In this case I read that we can create 600x600 pixels files and that will be displayed as thumbnails.
OR
@rdgrimes Do you think if MakeMKV or CloneBD could be further improved, the OPPO UDP-203/205 players could play "Seamless Branching" Atmos/TrueHD audio within the MKV container without dropouts? The reason I ask is that the OPPO UDP-203/205 players can play Atmos/TrueHD audio in the MKV container without any dropouts, I only seem to have audio dropout issues with "Seamless Branching" titles like Midway, since it has been around for 6 years you'd think the ripping tools would be able to fix this, I had heard that forum member @SamuriHL reported that CloneBD was much more effective than MakeMKV in ripping to MKV files effectively eliminating the dropouts issue but in my experience CloneBD was much worse, unfortunately DGDemuxGUI wasn't able to eliminate the audio dropouts at all but better than CloneBD.rdgrimes wrote: Sat May 22, 2021 4:19 pm Some tools claim to have fixed it for UHD, but its only fixed for SOME players. The Oppos still see the glitches and randomly drop out.
There was a fix implemented recently for LAVFilters concerning Atmos/TrueHD Seamless Branching audio dropouts here https://github.com/Nevcairiel/LAVFilter ... 3693941456, the commit fix https://github.com/Nevcairiel/LAVFilter ... da7170820f, the fix refers to "Account for a padding gap at seamless branching splice points when bitstreaming TrueHD", do you think this could be implemented in MakeMKV or CloneBD?
It doesn't really work like that. When moving a seamless branch title from m2ts files to mkv files, some of the timing information is lost (I'm vastly oversimplifying here). The issue is that frames overlap and/or have gaps. The way they are stored in an m2ts container is different than how they are stored in an mkv container. Your player will need to deal with it. The problems with ripping seamless branch titles with MakeMKV were fixed quite a long time ago, and using any player using LAV Filters will play them without issue. This is why I ported the LAV Filters code to CoreELEC Kodi a few months ago. M3GAN 2.0 was a prime example of the issue which is no longer a problem for any builds that incorporate the LAV Filters code. The issue is not with your rips.
@samuriHL Thanks for getting in touch, are you sure that there isn't any issue with my rips as like I said they do exhibit differences, in that CloneBD has more audio dropouts with this Midway Region A Lionsgate Blu-ray title than MakeMKV or DGDemuxGUI, DGDemuxGUI exhibits less dropouts but I also understand that the issue is with the OPPO UDP-203/205 players finicky imperfect handling of "Seamless Branching"Atmos/TrueHD audio with MKVs but it is still quite strange that the OPPOs have no issue with audio dropouts with Atmos/TrueHD in the MKV container with "non-Seamless Branching" titles, it's not even an Lionsgate disc issue as Ballerina has no audio dropouts on my OPPOs with its Atmos/TrueHD audio track.SamuriHL wrote: Tue Apr 28, 2026 9:22 pm It doesn't really work like that. When moving a seamless branch title from m2ts files to mkv files, some of the timing information is lost (I'm vastly oversimplifying here). The issue is that frames overlap and/or have gaps. The way they are stored in an m2ts container is different than how they are stored in an mkv container. Your player will need to deal with it. The problems with ripping seamless branch titles with MakeMKV were fixed quite a long time ago, and using any player using LAV Filters will play them without issue. This is why I ported the LAV Filters code to CoreELEC Kodi a few months ago. M3GAN 2.0 was a prime example of the issue which is no longer a problem for any builds that incorporate the LAV Filters code. The issue is not with your rips.
Do you think if the LAVFilters code were implemented in MakeMKV, CloneBD & DGDemuxGUI (already has a "Fix Gaps Correction" algorithm) it would rectify this issue specifically for OPPO UDP-203/205 players?
I also tried my luck with eac3to but no such luck there with similar behaviour to CloneBD exhibitng the same amount of audio dropouts.
I keep seeing you make this "if the LAVFilters code were implemented in" comment. NO. It does NOT work that way. LAVFilters is about playback, nothing more. It has nothing at all to do with how it's stored in an MKV.oniiz86 wrote: Wed Apr 29, 2026 12:51 pm @samuriHL Thanks for getting in touch, are you sure that there isn't any issue with my rips as like I said they do exhibit differences, in that CloneBD has more audio dropouts with this Midway Region A Lionsgate Blu-ray title than MakeMKV or DGDemuxGUI, DGDEmuxGUI exhibits less dropouts but I also understand that the issue is with the OPPO UDP-203/205 players finicky imperfect handling of "Seamless Branching"Atmos/TrueHD audio with MKVs but it is still quite strange that the OPPOs have no issue with audio dropouts with Atmos/TrueHD in the MKV container with "non-Seamless Branching" titles, it's not even an Lionsgate disc issue as Ballerina has no audio dropouts on my OPPOs with its Atmos/TrueHD audio track.
Do you think if the LAVFilters code were implemented in MakeMKV, CloneBD & DGdemuxGUI (already has a "Fix Gaps Correction" algorithm) it would rectify this issue specifically for OPPO UDP-203/205 players?
CloneBD, MakeMKV, and DGDemuxGUI all deal with seamless branching in MKV slightly differently. CloneBD is, to my knowledge, no longer updated and should no longer be considered. Back when this was an issue on Blu-ray and TrueHD, CloneBD was at the time the best solution. However, ATMOS has slightly made things more complicated. MakeMKV handles seamless branch titles just fine. DGDemuxGUI deals with it slightly differently but none of this matters to your player in the slightest.
As I said before, your player is not capable of properly handling seamless branch titles in an MKV container. If you want to avoid this issue, don't use MKV with that player. You can NOT fix this in the MKV so that your player will handle it properly no matter what program you use. Short of completely reauthoring the TrueHD/ATMOS track, anyway, and that's way outside my area of expertise plus the tools to do that are not cheap.
@samuriHL The reason I thought the LAVFilters code may help the demux/remux tools is that the LAVFilters developer made this comment here https://github.com/Nevcairiel/LAVFilter ... -495118712 "Thats the problem with seamless branching discs, when there is two variants its hard to unify them properly.SamuriHL wrote: Wed Apr 29, 2026 2:21 pm I keep seeing you make this "if the LAVFilters code were implemented in" comment. NO. It does NOT work that way. LAVFilters is about playback, nothing more. It has nothing at all to do with how it's stored in an MKV.
I could possibly fix it when playing directly from the disc or a folder rip with LAV Splitter, but if you do a MKV rip this information is lost, and the MKV ripping tool would need to be responsible to fixing it - which as far as I know, none do.
A Github user's response to this discussion "If we could get it to work with the folder rip, that would be a step forward, right? I would assume that by fixing it for the folder rip, you could then provide information how a generated MKV from this should look. With that information we could approach the ripping tools, in my case that would be MakeMKV and MKVToolNix, so they can fix it on their end."
It appears that the behaviour could potentially be improved or fixed by MKVToolNix's developer but unfortunately he doesn't seem interested in improving this aspect of MKVToolNix, the issue #2684 https://codeberg.org/mbunkus/mkvtoolnix/issues/2684 & the developer's understanding of the issue here https://codeberg.org/mbunkus/mkvtoolnix ... nt-3068224
It's a real shame that this MediaTek SoC quirk couldn't ever be properly rectified by the OPPO engineering team, they only merely improved the TrueHD/Atmos behaviour from the BDP-10x series of players which is quite awful even with non-Seamless Branching titles within the MKV container, I guess at least the OPPO UDP-20x players can play TrueHD/Atmos within the MKV container as long as it's not a "Seamless Branching" title.
You're misinterpreting what Nevcariel is saying. LAV Filters is still not going to help the MKV ripping tools. It's designed for playback. He's saying exactly what I've said....the MKV container loses certain information when moving from M2TS container to MKV. That information is what informs players on how to "merge" the two streams correctly during playback. In order for a ripping tool to fix it correctly, they would have to merge the stream so that it looks like one contiguous stream to the player. The logic is similar between the two but it's not identical because LAV Filters doesn't deal with storing the data, only reading it and correcting it before sending it to the audio device. It's actually a LOT more complicated than that. Having worked with his code for several months adapting it for CoreELEC, it's rather challenging. I understand why people don't want to deal with it in their respective code bases. They'd have to basically reauthor the stream on the fly which is not simple. CloneBD sort of took that approach but it doesn't work for all streams, especially for ATMOS.
Captain Ron
I have no problems with main title BDMV folder playback of UHD's.
Workflow.
1) Make full unencrypted back of disc using MakeMKV.
2) After this has completed go to "Open Files" in MakeMkv and browse the backup and open the DBMV/index.bdmv file.
3) Note the index file <number> down that is for the main title. It will usually be the largest one wih the most chapters and languages. e.g. 00800.mpls.
4) Run TSmuxxer GUI (Install the latest TSmuxxer and the matching TSmuxxer Gui if you don't have it).
5) In TSmuxxer Gui open the backup folder and BDMV/PLAYLISTS/<number>.mpls
6) Select the required video layer(s),soundtrack and subtitles (if required) only. If there are two video layers then select both. The 1080p layer is for Dolby Vision. Ensure the main layer is first in the order then the DV layer. I usually move them in the selection pane so that they are all consecutive
7) In the Blu-ray tab at the top ensure you have selected the required soundtrack and subtitle file default (if required) and that the chapters radio button is selected.
8) Select Blu-ray folder as the output format in the radio buttons at the bottom and your output path. I usually create a directory e.g. "Godzilla UHD" and target that
9) Hit Start Muxxing.
The resulting folder containing the BDMV and CERTIFICATE structures will then autoplay the main title on an Oppo 203 or 205. Dolby Vision / Atmos.
The same workflow works for 2D blurays as well but you need to use BDModifier (I use V2.0), select the containing directory and hit modify in order to enable autoplay on the Oppo.
3D bluray unfortunately isn't supported as an autoplay BDMV folder on stock 203/5's . You need to change step 8 above to select .TS or .M2TS and create that. You also have to ensure that the Primary video layer is first and the MVC offset 3D video layer is second. You lose chapters and scrubbing but it will play. Sometimes the eye layers get swapped and if your target playback system isn't an active 3D one where you can instruct it to swap the eyes then you have to either get clever with scripting to swap the eyes or have alternate glasses made with the lenses swapped.
Workflow.
