Artificial Inteligence
marcusfan
Post by marcusfan » Tue Jan 11, 2011 1:41 am
MakeMKV v1.6.3 darwin(x86-release) started
Opening files on harddrive at /Volumes/SansDigital/Movies/Artificial Inteligence/VIDEO_TS/
Titleset id 0 is invalid
setarip_old
Re: Artificial Inteligence
Post by setarip_old » Tue Jan 11, 2011 4:59 am
Hi!
Does the DVD play properly on your computer?
Does the DVD play properly on a standalone DVD player?
Check for physical damage and or dirt. Try cleaning the disc.
marcusfan
Post by marcusfan » Tue Jan 11, 2011 10:32 pm
It's a rip I did a while back. Plays fine.
Debug logging enabled, log will be saved as /Users/viewer/MakeMKV_log.txt
Opening files on harddrive at /Volumes/Movies/Artificial Inteligence/VIDEO_TS/
DEBUG: Code 0 at C&L\-k/}qO".d\.sa:29394045
setarip_old
Post by setarip_old » Wed Jan 12, 2011 6:17 am
Try re-ripping your original, commercial DVD DIRECTLY (and ONLY) with MakeMKV...
marcusfan
Post by marcusfan » Mon Feb 07, 2011 7:14 pm
Got it to work by converting to ISO using:
http://sourceforge.net/projects/aquaiso/
Then using MakeMKV.
Note choose the parent folder of the Video_TS folder while using AquaISO and not the acvtual Video_TS folder.
setarip_old
Post by setarip_old » Mon Feb 07, 2011 10:48 pm
Did you retry (without creating an .ISO image file) with MakeMKV pointed to your hard drive folder as: Opening files on harddrive at /Volumes/Movies/Artificial Inteligence/ (WITHOUT "VIDEO_TS")?
marcusfan
Post by marcusfan » Tue Feb 08, 2011 3:23 am
Tried it. Didn't work.
Post by mike admin » Tue Feb 08, 2011 10:06 am
