Are these flashable for UHD friendly?
Freaky69
Post by Freaky69 » Tue May 18, 2021 5:03 pm
Hello all,
i could get 2 drives for an reasonable price but I'm not sure if these are flashable to UHD friendly drives.
Maybe one of you could help me :)
Re: Are these flashable for UHD friendly?
Post by Woodstock » Tue May 18, 2021 6:23 pm
Both pre-date the availability of UHD-capability, so no. The hardware won't do it.
They should already be LibreDrive capable, which gives advantages, but that doesn't make up for the lack of UHD-capable laser assemblies.
Freaky69
Post by Freaky69 » Wed May 19, 2021 4:22 am
Thanks for your reply.
I thought at least the 2015 drive was capable :(
Freaky69
Post by Freaky69 » Wed May 19, 2021 5:22 am
So the Buffalo / Hitatchi Drive should work i hear??
Post by Billycar11 » Wed May 19, 2021 8:00 am
Freaky69 wrote: Wed May 19, 2021 5:22 am So the Buffalo / Hitatchi Drive should work i hear??
Yeah
Freaky69
Post by Freaky69 » Wed May 19, 2021 8:23 am
Is there something i have to be aware of by buying this drive?
Is it easy to flash?
Post by Billycar11 » Wed May 19, 2021 8:37 am
Freaky69 wrote: Wed May 19, 2021 8:23 am Is there something i have to be aware of by buying this drive?
it is slim sata
you can buy a self flash kit from me if you find my how to videos and guide to hard
Freaky69
Post by Freaky69 » Wed May 19, 2021 9:00 am
How much is it?
Post by Billycar11 » Wed May 19, 2021 9:06 am
Freaky69 wrote: Wed May 19, 2021 9:00 am How much is it?
$25 as listed in my post
Freaky69
Post by Freaky69 » Wed May 19, 2021 9:13 am
I will hopefully get an actual picture from the drive (if the seller will response to my mail).
After that i will post the picture what FW is installed on the drive.
then we can talk about the self flash kit ;)
Nevertheless i would like to know is there a fw available which isn't flashable?
Is the BU40N better than the ASUS BW-16D1HT 3.01?
I got the ASUS and sometimes it is very slow and produces Read errors but my standalone UHD Player (Panasonic) plays the disc fine!
Post by Billycar11 » Wed May 19, 2021 9:31 am
Freaky69 wrote: Wed May 19, 2021 9:13 am I will hopefully get an actual picture from the drive (if the seller will response to my mail).
from my tests the bu40n is better than the asus.
all firmware is currently flashable
Freaky69
Post by Freaky69 » Wed May 19, 2021 9:38 am
Thanks a lot Billy,
isn't it possible to use the Tool from Marty to flash the drive?
SDFTOOL with the DE_LG_BU40N_1.00 firmware?
This should be the easiest way, or am i wrong?
Post by Billycar11 » Wed May 19, 2021 9:58 am
Freaky69 wrote: Wed May 19, 2021 9:38 am Thanks a lot Billy,
you are possibly wrong on the firmware as i said follow the guide or email me for a kit when you get the drive
Freaky69
Post by Freaky69 » Wed May 19, 2021 6:48 pm
I just got the actual picture of the drive. It seems that there is the FW 1.03 installed :(
Is it okay to flash also?
Inkeds-l1600 (1)_LI.jpg (2.19 MiB) Viewed 17873 times
Post by Billycar11 » Wed May 19, 2021 7:10 pm
Billycar11 wrote: Wed May 19, 2021 9:31 am
But as I said your method to go directly to 1.00 de won't work
