Drive used to work, now just spits out discs (macOS)
skyzyx
Post by skyzyx » Tue May 18, 2021 10:51 pm
I have an external ASUS BC-12D2HT in a NexStar enclosure that I successfully patched the firmware for to create a LibreDrive around 18 months ago (I think; quarantine has made all the days run together). I've format-shifted multiple discs from UHD to H.265 using this drive.
Then I didn't do anything with discs for a while. During that time, I upgraded from macOS Mojave → Catalina → Big Sur. Presently I'm running macOS "Big Sur" 11.4. About 6 weeks ago, I tried to format-shift a new disc. The drive spun quietly for about 10-15 seconds, then spit out the disc. Not only is spitting out the disc odd, but the drive didn't sound like you were jamming a metal pipe in the garbage disposal like it used to.
I've tried a variety of 4K discs to no avail, including one that I've successfully format-shifted before. I've tried re-flashing the firmware using /Applications/MakeMKV.app/Contents/MacOS/makemkvcon, which worked without issue (as per viewtopic.php?f=19&t=21863). The drive is connected directly to a 2018 Mac mini Thunderbolt 3 port using a USB-C → USB-B SuperSpeed (3.0) cable.
The movie that I've successfully format-shifted before was purchased from BestBuy and came with both a Blu-ray and UHD Blu-ray disc. Both discs get kicked out after about 10-15 seconds.
$ /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f --list
Found 1 drives(s)
00: /IOBDServices/6ACD94D0
  ASUS_BC-12D2HT_3.11_211902271319_XXXXXXXXXXX
$ /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f --drive /IOBDServices/6ACD94D0 --sdf-file ~/Downloads/sdf.bin rawflash main --in ~/Downloads/mk-firmware-pack-20200720/MK/ASUS/BC-12D2HT/ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
Reading input file ~/Downloads/mk-firmware-pack-20200720/MK/ASUS/BC-12D2HT/ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
Current Drive ID: ASUS_BC-12D2HT_3.11_211902271319_XXXXXXXXXXX
yes
 100% Operation finished
Done successfully
Debug log started at Tue May 18 22:39:30 2021 , written by MakeMKV v1.16.3 darwin(x64-release)
001005:0000 MakeMKV v1.16.3 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/me/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin20.0) , proxy server not set.
002010:0000 Optical drive "BD-ROM ASUS BC-12D2HT 3.11d" opened in OS access mode.
SDF  v07e: ASUS_BC-12D2HT_3.11_211902271319_XXXXXXXXXXX
Before I go out and start buying new cables or replacing the drive, is there anything software-related that may be the culprit? I know that the rules around Notarization got stricter in macOS Catalina (which, mike admin, is pretty cheap/easy to do -- as long as you have a Mac). Perhaps since this is attempting to open the disc in "OS access mode", maybe there's something causing an issue?
Any help/direction is appreciated, and I'm not afraid of the Terminal. Thank you.
Re: Drive used to work, now just spits out discs (macOS)
Post by Billycar11 » Tue May 18, 2021 11:18 pm
try a dvd or cd and see if it works if so then your bluray laser died.
skyzyx
Post by skyzyx » Tue Jun 01, 2021 8:36 pm
  • No 4K UHD (tested several)
  • No Blu-ray (tested several)
  • No DVD
  • No CD
Everything just spins for a moment, then spits the disc back out.
Went ahead and ordered a new ASUS BW-16D1HT, so we'll see how that goes.
OakManor
Post by OakManor » Mon Jun 14, 2021 12:03 am
I have a similar situation where my working LibreDrive flashed enclosure stopped working and just spits out discs.
I have an external OWC Mercury Pro 16X Blu-ray, 16X DVD, 48X CD Read/Write Solution which comes shipped with a LG WH16NS40. When I received it at the end of 2020, I dumped the firmware settings that I could with sdftool and it produced:
dump_user_HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLIJ8Q83155.tar
I flashed it to
HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
It successfully worked across numerous DVDs and Blu-rays for almost half a year. At some point, without ever re-flashing it, the drive stopped reading any type of disc.
If I attempt to power-on the external enclosure with a Blu-ray inside the tray, the drive blinks blue and produces some spinning noises for 55 seconds until it stops spinning and stops blinking any lights. The tray does not automatically eject. This is repeatable and consistent. The OS reports the USB device is connected but MakeMKV reports no usable optical drives.
If I attempt to power-on the external enclosure with a DVD inside the tray, the drive blinks blue and produces some spinning noises for 35 seconds until it stops spinning and stops blinking any lights. The tray does not automatically eject. This is repeatable and consistent. The OS reports the USB device is connected but MakeMKV reports no usable optical drives.
Mercury Pro Optical:
  Product ID:	0xde2c
  Vendor ID:	0x1e91
  Version:	1.00
  Serial Number:	002933012615
  Speed:	Up to 5 Gb/s
  Manufacturer:	Other World Computing
  Location ID:	0x00700000 / 13
  Current Available (mA):	900
  Current Required (mA):	0
  Extra Operating Current (mA):	0
The program can't find any usable optical drives.
» sudo ./sdftool --list
Found 0 drives(s)
If I attempt to power-on the external enclosure with the tray empty, it appears to power on correctly and MakeMKV is able to detect it.
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.05d" opened in OS access mode.
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLIJ8Q83155
Highest AACS version: 76
Firmware version: 1.05
Disc Information
Disc is being loaded
Found 1 drives(s)
DEBUG: code=00000000 src=1@v]~"'&NQRffK@zW.l;."W\Q:29395149
00: /IOBDServices/D308F1C6
  HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLIJ8Q83155
However, when I only later insert a DVD inside the tray, the drink blinks blue and produces some spinning noises for 30 seconds until it ejects the tray. The same applies if I later insert a Blue-ray inside the tray except that case takes 50 seconds until it ejects the ray. Both are repeatable and consistent.
The only event that I can think of that could have had an impact on this drive would be an OS update from macOS Catalina 10.15.6 to macOS Catalina 10.15.7 (19H1217) but I would expect more users to be complaining of this issue if that were the cause.
What could have gone wrong? Any recommendations other than trashing it and buying a new drive?
Post by Billycar11 » Mon Jun 14, 2021 12:56 am
OakManor wrote: Mon Jun 14, 2021 12:03 am I have a similar situation where my working LibreDrive flashed enclosure stopped working and just spits out discs.
I flashed it to
  Product ID:	0xde2c
  Vendor ID:	0x1e91
  Version:	1.00
  Speed:	Up to 5 Gb/s
Found 0 drives(s)
Revision: 1.05
Disc Information
Found 1 drives(s)
Clean the disc
Try different discs
Clean the drive
Get BU40N
T'hain Esh Kelch
Post by T'hain Esh Kelch » Wed Dec 28, 2022 1:31 pm
I started having the same issue under macOS. My 10 year old Blu-ray no-name drive started spitting out discs because it couldn't read them. Usually I could just keep pushing the discs back in, and after more and more tries, macOS would finally recognize it and I could rip the disc without issue. Then we reached ~50 times before it would recognize anything, and short time after I just couldn't get it to read any Blu-ray discs at all.
Bought a new LG BP55EB40 drive today, and it read all my discs immediately without issue. I assume the failing to read discs thing is a clue for a failing laser.
