Game of Thrones
TheShoe
Game of Thrones
Post by TheShoe »
Has anyone had success ripping this series?
Of the 8 seasons,
season 2: Disc 1 and 3 fail; tried 5 different drives and two different pieces of software
season 8: Disc 1 fails, two different sets.
discs play fine in my Oppo UHD player, and oddly enough it seems I can (so far) copy the encrypted files and no reported read errors.
what is it about these discs?
season 1 and multiple other seasons i had to re-try multiple times to get a "clean" error free rip of many discs.
as for cleaning, I think i've tried about everything short of a rotary polisher at this point....
if the files copy (encrypted) and I can then create MKVs that would be something. unfortunately that means I can't decrypt the whole disc for a whole-disc backup, which I prefer...
anyway - curious what others have experienced.
Re: Game of Thrones
BU40N is the way to go
many have reported they have tried set after set on there current drive they gave up got a BU40N and right away it ripped all problem discs
TheShoe
Re: Game of Thrones
Post by TheShoe »
thanks. seems the copy (not rip) using Windows is also now stuck - i didn't watch the entire disc in the Oppo and it's entirely possible it won't play without issue either.
Amazing this set - after some searching around, it seems a lot of folks are having issues.
Maybe I'll try the other LG drive you mentioned...
TheShoe
Re: Game of Thrones
Post by TheShoe »
So...
I kid you not on this:
I took an orbital sander, a lambs wool disc, and Maguires 205 car polish that I had and polished the hell out of one of the discs.
It read perfectly.
Going to do another one and see what happens.
Mind you this is a disc that failed every single time across 5 drives; popped it in after the polishing and ripped perfectly no issues.
Digital moe
Re: Game of Thrones
Post by Digital moe »
Yes cleaning is the easy to go, so many of the discs failed to rip but some cleaning alcohol and a microfiber cloth fixed that. Some discs were more stubborn then others and needed 5 or 6 cleaning attempts.
TheShoe
Re: Game of Thrones
Post by TheShoe »
Well not bad. All failed discs but one worked after rotary sander + car polish polishing!
I'm going more aggressive on the one failed disc and see what happens.
What a nightmare ripping this series has been.
Anyway - add this to the list of options to clean a disc; in this case I tried all the usual recommendations for cleaning including multiple drives (5) to no avail.
