When I received the error, I thought bad disk.  But I used ddrescue to image disk and it completed 100% copied.  MakeMKV also fails on the image.  VLC plays image and physical disk fine.
OS device name: /dev/sr0
Current profile: DVD-ROM
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: SIK9IGAI8453
Firmware date: 2115-12-11 14:59
Highest AACS version: 72
Firmware version: 1.02
Disc Information
Label: 1000239131
Timestamp: 2011-12-05 17:17:19
Data capacity: 2.80 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 1 (PTP)
Using LibreDrive mode (v06.2 id=76A0C3CD522E)
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
CellTrim algorithm failed since title has only 1 chapters
Title #1 (0:00:02) was skipped due to navigation error
Title #2 (0:03:56) was skipped due to navigation error
CellTrim algorithm failed since title has only 2 chapters
Title #3 (0:23:11) was skipped due to navigation error
Title #4 (0:14:01) was skipped due to navigation error
Title #5 (0:21:15) was skipped due to navigation error
						[Fixed] Doctor Who: The Three Doctors Special Edition Disk 2
Re: [Fixed] Doctor Who: The Three Doctors Special Edition Disk 2
This problem no longer occurs with version 1.16.5.
