daddy
Post
by daddy » Fri May 14, 2021 5:07 am
Snickers333 wrote: ↑Thu May 13, 2021 9:13 am
Hey guys, after reading lots and lots of pages from this thread, i need your confirmation. I want to buy an Lg oled and I'm considering c9 or cx ( in poland at the time this is about 70 dollar difference ). Am I right saying that if i want to be able to play FEL Dolby vision from bluray versions i have to buy the c9, because the cx can't play this dual layer format and is only limited to MEL Dolby vision ? Thanks.
Yes, you are right.
Also, cx can't play dts audio.
Snickers333
Post
by Snickers333 » Mon May 17, 2021 12:56 pm
Guys, I have just made 2 mp4 files. One is first episode of Game of thrones in Dolby Vision FEL. Second is The invisible Man also in Dolby Vision. I made those files using original mp4muxer method - extracted base layer and enchancement layer .hevc files and merging them to make DTDL .mp4 files and here is the thing. My Lg CX when playing The invisible Man throws out an error something like couldnt recognise file, but then when i tried playing game of thrones episode it plays just fine !! recognizing Dolby Vision icon in the corner. Any idea why is that ? Maybe it's some sort of securing from playing longer files in Dolby vision ( just a guess ).
Dawid911
Post
by Dawid911 » Mon May 17, 2021 4:50 pm
Hi all pls help me how add audio and subtitle to mp4 video( 5 profile dv) ?
DaMacFunkin
Post
by DaMacFunkin » Tue May 18, 2021 5:46 am
Dawid911 wrote: ↑Mon May 17, 2021 4:50 pm
Use external srt format.
karbre
Post
by karbre » Tue May 18, 2021 1:24 pm
ultrahorst wrote: ↑Sun May 09, 2021 9:52 pm
karbre wrote: ↑Sat May 08, 2021 12:13 pm
Okay then, I guess the MKV as it came out of MakeMKV is as good as the one processed with MKVToolNix, as the DV data is not altered. I'm not planning on converting to other DV profiles.
Actually, this is not true for the latest MKVToolNix version:
https://gitlab.com/mbunkus/mkvtoolnix/-/issues/3093
Just a heads up, users in other forums reported that MKVs created with versions 56.0.0 and 56.1.0 without the program argument
--engage dont_normalize_parameter_sets
do not work in some players, and re-muxing with a lower version or the program arguments mentioned in the linked issue does not work.
Thank you very much for this information btw. I am now using MKVToolNix v55.0.0 for muxing DV files. I don't really understand why the MKVToolNix dev does not release a hotfix which disables the mentioned argument by default. I am pretty sure it does more harm than good for most users (it was introduced only for fixing edge-case problems when joining video files).
ultrahorst
Post
by ultrahorst » Mon May 24, 2021 8:38 pm
karbre wrote: ↑Tue May 18, 2021 1:24 pm
You're welcome! You can also use the new version v57 released two days ago. The author fixed many HEVC issues, including the DV header issue causing the bug introduced in v56.
ultrahorst
Post
by ultrahorst » Wed May 26, 2021 4:47 pm
DaMacFunkin wrote: ↑Mon May 10, 2021 5:58 am
On most movies the Zidoo Z9X will do you fine, if you absolutely feel you need full FEL then Ugoos am6+ with patched Kodi, but it is a real flaky box tbh.
Ugoos released a new firmware today (
https://ugoos.com/rc-firmware-update-v0 ... -x3-models), with video codec and stability fixes.
Might be worth checking out. I hope this update is a sign that the rumors about the abandonment of the AM6 are not true.
Mattl0
Post
by Mattl0 » Thu May 27, 2021 1:46 am
NiCE77 wrote: ↑Thu Feb 18, 2021 5:46 pm
I've tested the Ugoos AM6 Plus media player (Amlogic S922X-J), and it seems, the internal player correctly processing the
Full
Enhancement
Layer from DTDL mp4 file!
https://youtu.be/RYeLEYk_Bys
I'm tried with Kodi 19 custom build and working same with the P7 STDL mkv too!
Here , with movieayer ugoos am6 plus is sending 1080p to the tv with dtdl mp4 . Cheked with hidden menu on lgb6 (pressing 5times ‘’1’’ on chanel tuning menu)
Mattl0
Post
by Mattl0 » Thu May 27, 2021 1:57 am
mattmarsden wrote: ↑Wed Feb 24, 2021 2:16 pm
OK, dual track MP4 plays fine through the internal player with FEL so it must be a Kodi issue it not playing smoothly.
Please check if it is outputting in 1080p
bobbymkV
Post
by bobbymkV » Thu May 27, 2021 4:37 am
Life has been going too good, so decided to check out the AM6+ v0.4.1 "RC" firmware even though it's very late. My only use case is playing FEL mkv with the special Kodi.
Still random whether a media file plays or not? CHECK
Video jumps forward 30-40 seconds and stutters? CHECK
Have to mash on the power button half the time you try to stop playing? CHECK
Seems 0.4.1 won't fix the issues we have with FEL.
bobbymkV on Sat May 29, 2021 2:25 pm, edited 1 time in total.
daddy
Post
by daddy » Thu May 27, 2021 7:43 am
Is there someone who tryed the new
Dune HD Real Vision 4K ?
https://www.dune-hd.com/products/dune-hd-real-vision-4k
It seems to be the long awaited product ...
Playback of Dolby Vision Blu-ray images
The media player supports direct playback of full Blu-ray disc images (BMDV and ISO) in Dolby Vision format (MEL and FEL), even when using full Blu-ray menu. The extended Dolby Vision information is used and transmitted to the TV to improve the picture quality. This is possible due to the unique video playback and output engine created by Dune HD. Other RTD1619DR-based media players do not support this. Dune HD media players are the only hybrid network media players in the world that combine support for Dolby Vision Blu-ray disc images with support for Internet video services and Android applications in one device.
Widest support for Dolby Vision file formats
Dolby Vision is supported for all popular file formats (BDMV, BD ISO, MKV, MP4, TS, M2TS). All popular Dolby Vision profiles (P4, P5, P7 MEL and FEL, P8) are supported. The media player supports the largest number of variations of Dolby Vision file formats of any other media player.
Post
by shawnc22 » Thu May 27, 2021 3:31 pm
daddy wrote: ↑Thu May 27, 2021 7:43 am
Pretty sure there's no difference between all the other existing Realtek 1619DR based products out there. Dune has done this in the past in that when they mention "FEL support", they don't actually mean they utilize data from the FEL. It just means that the device can safely ignore the FEL, apply the DV RPU data directly onto the BL, and playback FEL content without issue (just like the Shield, Zidoo Z9X, and couple other Dune players). There's likely a hardware limitation to the Realtek SOCs that prevents full FEL support.
bgalakazam
Post
by bgalakazam » Thu May 27, 2021 4:14 pm
No HDMI 2.1, same price as Shield Pro...
Can somebody say if it support FEL by actually playing back the data?
Sony X700 -> Onkyo TX-RZ830 -> LG C8
Post
by shawnc22 » Thu May 27, 2021 4:49 pm
bgalakazam wrote: ↑Thu May 27, 2021 4:14 pm
What're you trying to watch that requires hdmi 2.1 on a media player?
nekno
Post
by nekno » Fri May 28, 2021 12:01 am
Anyone know what would cause FF/RW to work on the Sony X700 playing an m2ts dvhe.07 FEL file from USB that's 2mins long, but not on a file that's 3hrs long?
