Forced subtitle stream crashes BDSup2Sub
ptr727
#1 Post by ptr727 » Thu Jan 27, 2011 11:56 pm
Hi, I noticed that when I open the forced subs only SUP stream created by MakeMKV in BDSup2Sub, that it crashes BDSup2Sub.
Process 1:
Avatar BD
MakeMKV including DTS-HD, DTS, English subs, and English forced subs.
Use EAC3TO to extract two subtitle streams to SUP files from MKV.
Open normal subs using BDSup2Sub, ok.
Open forced subs using BDSup2Sub, crash.
Process 2:
Avatar BD
MakeMKV BD copy and decrypt to folder.
Use EAC3TO to extract the English subtitle stream to SUP file.
Open SUP file using BDSup2Sub, ok.
Save SUP file and select forced subs only, ok.
Re-open forced subs, ok.
The MakeMKV subs stream is 40,221,848 bytes.
The EAC3TO subs stream is 40,221,848 bytes.
The MakeMKV forced stream is 1,851,474 bytes.
The BDSup2Sub forced stream is 1,855,634 bytes.
Notice the difference in the forced subs stream sizes.
Is this a bug in MakeMKV?
P
Romansh
Re: Forced subtitle stream crashes BDSup2Sub
#2 Post by Romansh » Sun Feb 06, 2011 11:35 pm
Could also be a bug in eac3to - it's possible it doesn't extract the forced subs track from the MKV correctly.
Have you tried extracting the forced subs from the MKV with mkvextract instead?
Bling2Ming
#3 Post by Bling2Ming » Mon Feb 07, 2011 9:08 pm
I also think this may be an eac3to issue.
I own the Avatar Extended Collectors Edition Bluray, and I can confirm, that the extracted forced sub (PGS or .sup) stream from the mkv file created by Makemkv, when extracted with mkvextract, is handled without problems by BDSup2Sub.
ptr727
#4 Post by ptr727 » Mon Feb 07, 2011 9:11 pm
The stream extracted by eac3to and mkvextractgui are identical.
And a second user in the BDSup2Sub forum confirmed the problem:
http://forum.doom9.org/showthread.php?p=1475469
