I've had this posted in another section of the forum (wrong forum) and believe that im now posting in the right section.
I've recently decided to rip my blu-ray collection to mkv files and for the most part, so far so good.
With Disney Pixar blu-ray movies, there seems to be several files that are roughly the same size and I have always chosen the first one, removed the languages and subtitles that I don't want and create the mkv file.
However, with Wall.e choosing the first file did not seem to work for me. The film audio is in English which is what I want but for example the scene at 4:02 ( 4 minutes 2 seconds) has Wall.e riding on a news paper which is in written in French. When I playback the Blu-ray in English, that same scene has the newspaper in English. So I guess when i chose the first file to convert to mkv, it was obviously not the English Angle. I'm having a hard time determining which one is the English Angle.
please see images below:
the first one is a shot of all the files (expanded)
The second is a shot off all the files (not expanded)
Please help me determine how to rip my blu-ray (Movie Only) to MKV with English audio and angle.
Wall.e Blu-ray to MKV help needed for English Audio, Angle
ottawaxblade
- The second is a shot off all the files (expanded)
- walle.JPG (98.03 KiB) Viewed 23358 times
- the first one is a shot of all the files (not expanded)
- walle1.JPG (59.5 KiB) Viewed 23358 times
Re: Wall.e Blu-ray to MKV help needed for English Audio, Ang
The information found in the right pane of MakeMKV (playlist, angle) is more useful.
ottawaxblade
As per your request, I took a screen shot to show the info for each file in the 22.X GB range ( there are 9 files that are 22+ GB in size)
Still not sure how to determine the English track with English angle though.
Hope someone can help
*EDIT* just found out that i can only post 3 images max
- 03.JPG (108.58 KiB) Viewed 23334 times
- 02.JPG (109.05 KiB) Viewed 23334 times
- 01.JPG (104.93 KiB) Viewed 23334 times
I would try the title with the lowest playlist number first (maybe 00080.mpls, if it's the right size).
Or maybe quicker, try each title using the stream function: http://makemkv.com/forum2/viewtopic.php?f=1&t=703
setarip_old
@ottawaxblade
Hi!
http://forum.slysoft.com/showpost.php?p ... ostcount=5
Hi!
If anybody is interested the correct mpls file to use is 81"
Fortissimo
Thank you!If anybody is interested the correct mpls file to use is 81"
