BU40N Firmware version PRO4
lilsheep23
Post by lilsheep23 »
I just bought a BU40N external drive. I've read the main threads regarding downgrading the firmware but I cannot seem to find the appropriate version for my drive:
Product: BD-RE BU40N
Revision: PR04
Serial number: 904HS011039
Firmware date: 2118-12-24 16:04
Bus encryption flags: 1F
I cannot find any references on this forum referencing PRO4, any suggestions are welcome.
Many Thanks!
Re: BU40N Firmware version PRO4
flash to 1.03mk as the guide says
it says any firmware
lilsheep23
I've tried downgrading to 1.03mk using SDFtool but I get the same error code: 0x8f052400 . I've attempted all of the variations of the firmware for BU40N but none have worked.
Note that I am using a Windows 10 VM to attempt the downgrade; the drive was also bought in China so I believe I'm looking at different firmware.
lilsheep23 wrote:
Fri May 14, 2021 12:42 am
no vms thats your problem
lilsheep23
Ok, so I had an IT guy at work help me out and set it up on a Windows desktop. Tried it first via USB connection, then via SATA. Still the same error code: 0x8f052400.
lilsheep23 wrote:
Tue May 18, 2021 10:02 pm
then it may be time to buy a preflashed drive from one of the sellers
lilsheep23
I live in China, the cost of customs would be prohibitive.
Try the ASUS modified flasher instead of SDFTool.
GUNNER
Post by GUNNER »
Coopervid wrote:
Thu May 20, 2021 9:30 am
What he said. I had the same issue as you using the SDFTool. I used the Asus modified flasher in Administrator mode and it flashed my new BU40N with 1.01 firmware to HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 firmware and it rips 4K just fine
