Cosmic Sin: Unknown Key
Mankra
The UHDs is with an unknown key
Re: Cosmic Sin: Unknown Key
Did you submit the .TGZ file generated to svq@makemkv.com as requested in the UHD FAQ at the top of this forum?
Mankra
I thougt, it´s at the attachment, ok now again.
Uploading it here does not get it into the processing queue; that requires emailing it to svq@makemkv.com .
Mankra
Ok, thanks.
Email sent.
Email sent.
willi3
Hello Woodstock, you already asked me that question. And yes, I had already handed over .tgz for Cosmic Sin on May 6th. Unfortunately there is currently no key for this UHD disc. Stay healthyWoodstock wrote: Wed May 12, 2021 12:50 pm Did you submit the .TGZ file generated to svq@makemkv.com as requested in the UHD FAQ at the top of this forum?
(Google Translate)
willi3
vielen Dank an das Team !
