Visual commentary - what is this?
Legenista
Post by Legenista » Tue May 11, 2021 5:29 pm
I have this DVD:
http://dvdcompare.net/comparisons/film.php?fid=422
And as you can tell from these images:
https://imgur.com/a/ec9i4VA
It has an extra feature called VISUAL COMMENTARY. I used a program to create an ISO, with the option "Rip to Image".
Then I used MAKEMKV to convert everything into Matroska.
Also used PowerDVD to access the DVD from this decrypted ISO, mounted.
The problem is that no matter where I go (Matroska or PowerDVD) I can only see the following:
- The "visual commentary" is an audio commentary featuring these two people. Besides that it is a subtitle (which I checked using SUBTITLE EDIT) with over 2 hours saying the same thing:
In order to properly view the video commentary you must set your DVD player to 4x3 display mode. Consult your DVD player manual for specific instructions.
So what is this extra feature? Because I can only see this audio commentary and this subtitle saying the above.
I am now assuming this extra feature can't be viewed using any known player (like PowerDVD) or converted into Matroska by any software. So the only way of seeing is using a regular DVD player?
Meaning there's no way to access this using a PC?
This is the first time I am seeing this problem. I thought everything, no matter what, was accessible using a PC and specific software, so we could (if we wanted) ditch a regular TV and DVD/BD/4K player.
This visual commentary suggests otherwise.
Re: Visual commentary - what is this?
Post by dcoke22 » Tue May 11, 2021 6:56 pm
I have this movie on blu-ray. When I use the .mkv with MPV (https://mpv.io) I can see the 'visual commentary.' It seems like their attempt on Mystery Science Theater 3000.
