Do you have the segment map: 502,508,501,514,506,503,505,515,513,512,504,507,511?makeroflostsouls wrote:I see 440 has been listed as the correct file to copy. But my disk does not have this number listed. I have the blu-ray included in the 4k pack. Any one else have this issue? Thanks
John Wick Chapter 2
Lovely Rita
Re: John Wick Chapter 2
Make sure you check the top of the list - if MakeMKV thinks it found a match, it won't be in numerical order - it will be at the top.
makeroflostsouls
Thanks, never noticed that before..Woodstock wrote:Make sure you check the top of the list - if MakeMKV thinks it found a match, it won't be in numerical order - it will be at the top.
Lovely Rita
When this disc was first released the Java Runtime Engine did not list a Main Feature.
Whenever I run across a disc that does not I will forward Mike the required files (I'm sure others do the same) to help fine tune the JRE feature.
I just tried this disc again and it now DOES list a Main Feature (at the top, as Woodstock pointed out)
John Wick Chapter 2 - 16 Chapter(s), 33.8 GB (FPL_MainFeature)
Which turns out to be 440.mpls.
Wndsurfr
Does anyone know why the Netflix version of the main feature (19.8GB) is almost half the size of the retail version (33.8GB)?
whymyname
Resurrecting and hoping someone will see this.
I'm late to the game and read through the thread, my Netflix does not have 440 or 934. It does have 607, but I never read anywhere if that was correct?
preserve
Because they wanted to reduce costs and squeeze it onto a single layer disc?Wndsurfr wrote:Does anyone know why the Netflix version of the main feature (19.8GB) is almost half the size of the retail version (33.8GB)?
Using: ASUS BW-16D1HT 3.00
daves_ale
Bump, so the Netflix JW2 MPLS 934 is a bust. Matched up the maps and everything.
MPMS 440 does not exist. The only MPLS with a different time duration fails also (701).
Please help
Please help
SouperDeu2
daves_ale wrote: Mon Apr 29, 2019 10:43 pm Bump, so the Netflix JW2 MPLS 934 is a bust. Matched up the maps and everything.
Please help
I'm using the "Back Again" version from RB and discovered that the very first full-length feature file listed shows 440. Odd, as I expected to find it chronologically. Doing the rip now and hoping for the best.
When MakeMKV recognizes the proper file (and it did for me on JW2), it moves it to the top of the list.
ixion
After reading the entire thread, it seems like some people getting the disc from Redbox are getting a retail version of the disc (with TrueHD audio), this is not surprising, I have seen this with Netflilx as well, where I received a retail version while others reported getting a non-retail (you can usually tell by whether TrueHD is there or not).
Here is the consensus on this thread so far:
US Netflix (without TrueHD audio)
00934.mpls
Segment map: 502,505,512,504,516,515,513,506,509,510,514,518,511,501,520,503,519,508,507,517
US Retail (with TrueHD audio)
00440.mpls
Segment map: 502,508,501,514,506,503,505,515,513,512,504,507,511
US Redbox (with TrueHD audio, same as retail)
00440.mpls
00934.mpls
00440.mpls
00440.mpls
oddeyeball
00440.mpls works with the steelbook 4k edition of john wick 1&2 from bestbuy.
MovieDude17
I am verifying that this Segment Map is correct for the Netflix version, however my copy has file name John_Wick_Chapter_2_t371.mkvunab0mb wrote: Tue Jun 13, 2017 10:51 pm Correct title for Netflix version:
Title information
Name: John Wick Chapter 2 (English)
Source file name: 00934.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 20
File name: John_Wick_Chapter_2_t369.mkv
I did verify the Segment Map by playing the MKV copy side by side the Blu Ray Disc and checking each scene
Thanks for providing the correct Segment Map and saving me tons of time : )
Manyfold
Could anybody give a hint regarding the European / German version?
In this version, there are 37 .m2ts files. The one with the highest number is 00046.m2ts. Notably, there are no files from the 00500 range.
The only playlist which could be correct there is 00002.mpls, because this is the only one which includes 7.1 audio. It includes one segment, 00002.m2ts. So far, so good, but what worries me is the fact that its length is 02:03:03, while the correct length according to the statements in this thread should be 2:02:22. I suppose that they didn't add anything in the European / German version?
Any ideas?
Thanks a lot in advance!
Any ideas?
realshadow
There was another disk in Canada starting with 514. Took me a day but I was able to figure it out. the right data is:
hope that helps someone.
Title information
Source file name: 00796.mpls
Duration: 2:02:22
Chapters count: 16
Segment count: 13
Segment map: 514,501,503,502,511,504,515,505,513,508,507,506,512
File name: John_Wick_Chapter_2_t273.mkv
