Independence Day (ID4) - 20th Anniversary
Stryker412
Post by Stryker412 »
Just need some help finding the right track for ID4 UHD 20th Anniversary. I see there are two tracks each for the theatrical vs extended cut.
Re: Independence Day (ID4) - 20th Anniversary
I don't own that disc, so I can't check locally. Are there segment map differences between the two tracks? Or, perhaps, only the audio languages are different? It isn't uncommon for one title to be English, Spanish, French, etc. and the other title to be English and Japanese.
If there's a difference in the segment maps and you've made a decrypted backup of the disc, you can use a player like MPV (https://mpv.io) or VLC (https://www.videolan.org/vlc/) to view the 'changed' segments and determine a difference. Pixar movies in north America, for example, often have three titles. One with English titles, one with Spanish title, and one with French titles. The segments are located in <backup folder name/BDMV/STREAM/.
Spacebar
Post by Spacebar »
ID4 20th Anniversary Edition 2 Disc Blu-Ray
Theatrical Version 00850
Extended Cut 00801
