FlyByWire1
Re: SDFtool Flasher
Post by FlyByWire1 » Sun Apr 11, 2021 9:07 am
I read that there is no slim drive that is working with AnyDVD?! So my aim is to rip UHD movies to my NAS and stream with KODI to the TV. I do not want to make copys of the BD. Is there any benefit using AnyDVD (meaning I would have to buy another drive like the ASUS BW-16D1HT or LG BH16N55)?
Re: SDFtool Flasher
Post by Billycar11 » Sun Apr 11, 2021 9:22 am
FlyByWire1 wrote: Sun Apr 11, 2021 9:07 am I read that there is no slim drive that is working with AnyDVD?! So my aim is to rip UHD movies to my NAS and stream with KODI to the TV. I do not want to make copys of the BD. Is there any benefit using AnyDVD (meaning I would have to buy another drive like the ASUS BW-16D1HT or LG BH16N55)?
i dont think there is any benefit to anydvd you can always make an iso with img burn really only 1 extra step
most people who use anydvd want iso when they ask me
ZU476B72N4PC
Re: SDFtool Flasher
Post by ZU476B72N4PC » Sat Apr 17, 2021 7:53 pm
I had a new WH16NS40 with encrypted firmware 1.05, when I tried to flash to 1.02 MK (enc checked) I get the following error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at sdftool_flasher.Form1.<>c__DisplayClass36_0.<<button_START_Click>b__2>d.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
... But as it turns out, I'm just an idiot. The drive tray was open, and when I closed it the tool worked fine.
mohsiddiqui
Re: SDFtool Flasher
Post by mohsiddiqui » Sun Apr 18, 2021 10:53 pm
Does anyone know if there will be a Mac compatible version of the SDFtool?
Re: SDFtool Flasher
Post by Woodstock » Sun Apr 18, 2021 11:13 pm
You mean, like the one that ships with MakeMKV?
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Apr 19, 2021 12:37 am
mohsiddiqui wrote: Sun Apr 18, 2021 10:53 pm Does anyone know if there will be a Mac compatible version of the SDFtool?
I am working on a GUI but it is still a while away yet.
As Woodstock said, MakeMKV's built in sdftool command line is available or you could ask someone with a windows machine.
arrgh
Re: SDFtool Flasher
Post by arrgh » Wed Apr 21, 2021 8:15 pm
I Have a Hitachi-LG-BH16NS55 with firmware 1.05;;
I try to flash DE1.02 but get the below error ; I checked "enc"
I'm on Win10x64;
do I need to flash the MK firmware first?
edit: yes, its needed; done; worked;
thanks
esottwalker
Re: SDFtool Flasher
Post by esottwalker » Thu May 06, 2021 7:27 pm
I purchased the WH14NS40 and info from MakeMKV is below.
Product: BD-RE WH14NS40
Revision: 1.05
Serial number:
Harware support: Yes
Firmware support: No
Firmware version: 1.05
I first tried flashing the DE 1.05 version of the firmware which appeared to be successful. I couldn't read any UHD discs. I then tried flashing the MK 1.05 version which appears to succeed as well but I still can't read UHD discs. My drive is installed in an OWC Mercury Pro enclosure. I'm clearly doing something wrong. Anyone have any suggestions? I'm running Windows 10.
Re: SDFtool Flasher
Post by Billycar11 » Thu May 06, 2021 10:25 pm
esottwalker wrote: Thu May 06, 2021 7:27 pm I purchased the WH14NS40 and info from MakeMKV is below.
Revision: 1.05
Serial number:
What firmware were you originally on?
Chris Kelly
Re: SDFtool Flasher
Post by Chris Kelly » Fri May 07, 2021 4:59 pm
Just confirming that the latest factory firmware for the ASUS BW-16D1HT is not encrypted being that it was released in March of 2019. If I try installing nonencrypted MK firmware on a drive manufactured with new, encrypted firmware without checking the Enc box, could that damage the drive, or would the update refuse to load and I only get an error message? Also, what would happen if I check the Enc box when the factory loaded firmware is not encrypted?
esottwalker
Re: SDFtool Flasher
Post by esottwalker » Fri May 07, 2021 5:47 pm
Billycar11 wrote: Thu May 06, 2021 10:25 pm
Revision: 1.05
Serial number:
It was on 1.05
I was finally able to figure it out. I originally flashed the MK 1.05 firmware, it appeared to work but never did. After going round and round and trying other firmware's and other tools to downgrade, I started from scratch with the MK 1.05 firmware and it worked this time. I'm currently testing a rip of Interstellar.
impeeza
Re: SDFtool Flasher
Post by impeeza » Mon May 10, 2021 1:54 am
esottwalker wrote: Fri May 07, 2021 5:47 pm
It was on 1.05
Hi sorry for bother, but where did you get the 1.05 MK firmware? Thanks a lot.
Re: SDFtool Flasher
Post by MartyMcNuts » Mon May 10, 2021 3:20 am
impeeza wrote: Mon May 10, 2021 1:54 am
It was on 1.05
viewtopic.php?f=16&t=24443
impeeza
Re: SDFtool Flasher
Post by impeeza » Mon May 10, 2021 3:29 am
MartyMcNuts wrote: Mon May 10, 2021 3:20 am viewtopic.php?f=16&t=24443
Thank you very much
impeeza
Re: SDFtool Flasher
Post by impeeza » Mon May 10, 2021 4:29 am
MartyMcNuts wrote: Fri Feb 12, 2021 12:02 am The tar file does not contain the complete fw from your drive. It only contains the important fragments, making it possible to create a complete fw file by using another fw file and replacing those important sections.
The tar file cannot be used for recovery.
Did you even read the instructions?? Please don't listen to brucehvn. I know he is trying to help you but he has no idea what he is talking about.
Regarding your issue,
When you say you updated the drive to 1.05, did you mean the official 1.05 via LG's website? or the MakeMKV 1.05-MK firmware?
If you updated via the official LG 1.05 flashing tool, you must flash the drive to a MK firmware (I recommend WH16NS60 1.02-MK) then flash to a DE firmware (I recommend DE WH16NS60 1.00), then use the old DOSFLASH method to recover your drive.
Read here: https://www.makemkv.com/forum/viewtopic ... 15#p104021
Hi now time for the very noob question :D :
when you use the «READ Firmware» option, you get a Tar file, ok, there is any guide to create a correct firmware file to be restored to drive using the bin files on it? thanks for you time.
