MakeMKVcon
MakeMKVcon
I was able to get MakeMKV to convert a bunch of DVD's on my hard drive with the batch command, but for the life of me I cannot get it to work with a bluray that has been ripped down to my hard drive. I have a blu-ray movie that I used TSMuxer on to only have the movie itself. And I want to convert that to a MKV file. Can someone please help me out with the correct syntax for the MakeMKVcon command for a blu-ray.
- Contact:
Re: MakeMKVcon
the syntax is exactly the same as for dvd. Try to open it from GUI first - open a "index.bdmv" file in BDMV directory. For console version please specify the path to folder that contains BDMV directory.
Re: MakeMKVcon
Hi Mike,
OK the "index.bdmv" is under the BDMV folder for the bluray. And as you can see my syntax is pointing to the folder and below is the results I get.
Thanks,
Wayne
Thanks,
Wayne
C:\Program Files (x86)\MakeMKV>makemkvcon info file:"N:\Blu-Ray Movies\Bolt\BDMV
Current action: Scanning CD-ROM devices
Current progress - 0% , Total progress - 0%
Current progress - 100% , Total progress - 0%
Current progress - 100% , Total progress - 100%
Current progress - 0% , Total progress - 100%
003006:000000:0000 Opening files on harddrive at N:\Blu-Ray Movies\Bolt\BDMV
Current action: Processing advanced titleset
Current action: Pre-calculating data
Current action: Processing title sets
005010:000000:0000 Failed to open disc
Total 0 titles
Re: MakeMKVcon
Might try specific path..............\BDMV\index.bdmv.
Re: MakeMKVcon
Same Failed to open disc when I point directly to the index.bdmv file.
\index.bdmv"
003006:000000:0000 Opening files on harddrive at N:\Blu-Ray Movies\Bolt\BDMV\ind
ex.bdmv
Total 0 titles
- Contact:
Re: MakeMKVcon
Do not specify "BDMV" directory. In your case it should be just "N:\Blu-Ray Movies\Bolt". From gui you can just select file and MakeMKV will strip the path tail automatically.
Re: MakeMKVcon
That Worked... Thanks So Much....mike admin wrote:Do not specify "BDMV" directory. In your case it should be just "N:\Blu-Ray Movies\Bolt". From gui you can just select file and MakeMKV will strip the path tail automatically.
