Support IINA.app in Integration under MakeMKV preferences
macritzuko
Post by macritzuko » Sat Mar 20, 2021 9:22 pm
Tested version:
IINA 1.2.0
https://github.com/iina/iina/releases/d ... v1.2.0.dmg
MakeMKV v1.6.3
https://www.makemkv.com/download/makemk ... .3_osx.dmg
OS version:
macOS 10.13.6 (17G14042)
Description of the problem:
I have IINA.app under /Applications but MakeMKV does not show IINA.app. The support is missing.
It would be great if support for IINA.app can be added.
adamlogan
Re: Support IINA.app in Integration under MakeMKV preferences
Post by adamlogan » Mon Apr 26, 2021 2:39 am
+1 for this. I love IINA
SimonM
Post by SimonM » Wed May 05, 2021 3:47 am
IINA is a great player, but it's still missing a few features. I can't access a DVD's menu and view bonus content, it only plays the main (longest?) title. I'd like a DRC option in the equaliser as well.
Other than that it's great.
Post by Billycar11 » Wed May 05, 2021 6:47 am
macritzuko wrote: Sat Mar 20, 2021 9:22 pm Tested version:
IINA 1.2.0
MakeMKV v1.6.3
OS version:
Even if makemkv does not nativity support it with the easy integration tab you can do it the old way if iina supports libbd
Post by dcoke22 » Wed May 05, 2021 1:22 pm
Billycar11 wrote: Wed May 05, 2021 6:47 am Even if makemkv does not nativity support it with the easy integration tab you can do it the old way if iina supports libbd
IINA is a Mac specific wrapper around MPV and youtube-dl.
I have no idea if this will work, but maybe: https://github.com/iina/iina/issues/3363
