DolbyVisionFTW
Post by DolbyVisionFTW » Mon May 03, 2021 9:24 am
Donpablo80 wrote:
Sun May 02, 2021 7:27 am
Recently I bought the 65 inch LG Oled CX. I have a lot of MP4 Dolby vision movies that play fine on my older Oled B7, but they are not whatchble on my CX, they look very dark. Is this a known problem?
EDIT:
I see it's a known problem. Anything to do about it? Or just download the hdr10 version of the movie.
You could try some of these suggested settings on this reddit thread:
https://www.reddit.com/r/OLED/comments/ ... me=iossmf
seems to have improved things for a bunch of people.
MastaG
Post by MastaG » Mon May 03, 2021 7:59 pm
I received the clone of the Oppo blu-ray player last month.
It's called M9201 and it's basically the same thing but without the actual disc-reader.
There is a monthly bulk import of these things on a spanish forum.
It plays everything I throw at it.
Now I can just open the blu-ray iso files from my nas and it will even display the full menu's (it's a blu-ray player after all).
Mattl0
Post by Mattl0 » Mon May 03, 2021 11:46 pm
Hi ,
I am trying to figure out if my lg b6 can do tv led (rgb tunelling) in general? So I am wondering if it is really processing the dolby vision fel with mkv/mp4 rips from ugoos am6 + and if it is tv led or player led .
I know I can watch mp4/ts dolby vision fel directly with a usb ssd attached on the tv, but this is not convenient and the tv player always stop with a lack of memory message.
Even there , how can i be sure the tv is processing the fel?
Stdl and dtdl seems play fine on usb.
The info is hard to find for the 2016 lg models. So i am wondering if I should sell my b6 for a b9-c9? I am also looking at buying the vertex to be able to answer some of my questions but if someone has the answers it would be great.
phbart
Post by phbart » Tue May 04, 2021 12:17 am
EDIT:
I guess I'll be keeping my B7 after all. Going strong since Dec/2017 with almost 6500 hours of use.
Btw, is it possible already to play DV with MKV containers? Or just mp4?
jkatchy2
Post by jkatchy2 » Wed May 05, 2021 10:17 pm
shawnc22 wrote:
Sat Apr 24, 2021 10:14 pm
Epedemic wrote:
Sat Apr 24, 2021 9:41 pm
As for the x700, you're gonna have to demux your .mkv DV library back into 2 separate video tracks with yusecope's tool and then remux it into a ts/m2ts container for the x700.
Is there any link to yusecope's tool latest version ?
ragico
Post by ragico » Thu May 06, 2021 11:43 am
viewtopic.php?f=12&t=18602&p=96282#p96282
karbre
Post by karbre » Thu May 06, 2021 11:39 pm
Please forgive me for not reading 300+ pages, I'm sure it has all been discussed, but can someone please sum the DV situation up for me...
I do not yet have the hardware (playback device, display) for DV, but I want to rip my UHDs in the best way possible and store them on my NAS. I will buy the playback hardware specifically with DV in mind, so I don't need to store the files in any compromise format that some non-ideal playback devices might need.
My toolflow is MakeMKV + potentially gMKVExtractGUI for extracting PGS subtitles and then mkvToolNixGui to rip SRT subtitles back in and potentially changing header data. Can I use that flow 1:1 without messing up the Dolby Vision information? Of course I use the latest versions on all tools.
Post by dcoke22 » Fri May 07, 2021 12:01 am
Recent versions of MakeMKV will store all the DV data in the .mkv file. If you've got the space, keep the unedited rips. It is likely that a year or two from now the playback situation will be different than it is today.
MKVToolNix version 49 or later will preserve DV data. https://www.bunkus.org/blog/2020/08/mkv ... -released/
karbre
Post by karbre » Fri May 07, 2021 12:58 am
Thank you for the link to MKVToolNix. So my toolflow should still work.
What do you mean by "keeping the unedited rips" - keeping the MKVs as they came directly out of MakeMKV, or keeping a complete disc backup?
If it's the first case: Does that mean you don't trust MKVToolNix / mkvmerge to not mess up the metadata?
If it's the second case: My understanding is that MakeMKV stores all the Dolby Vision data that is available in the MKV, right? So if something changes with the requirements on the file format, it should be able to convert from the MKV produced now as all the information is in there. Or am I missing something?
Post by dcoke22 » Fri May 07, 2021 1:27 pm
I mean keeping the .mkv files as they come out of MakeMKV. I didn't quite finish my thought there… What comes off a UHD and gets stored in the .mkv file is Dolby Vision profile 7. There is some support for playing DV profile 7 directly, but it isn't universal. Dolby Vision profile 5 is what the streaming services use and is what has the most support with built-in players in TVs and various streaming boxes. There are tools to get from profile 7 to profile 5, but I think most people are wanting to eventually just play the profile 7 .mkv files directly. Transcoding a DV UHD rip to save a little space is a multistep process at the moment as well.
In summary, the tools and best practices for dealing with UHDs, especially DV UHDs are in flux. By keeping the 'unedited rips' you should be able to avoid having the rip from disc again when circumstances change (i.e. when your playback setup changes or whatever).
As a side note you should be able to get nearly the all the metadata correct in MakeMKV at the time of ripping (except, of course, any .srt subtitles you might want to embed).
Mattl0
Post by Mattl0 » Sat May 08, 2021 6:50 am
Yeah here I keep iso’s in a hdd.
karbre
Post by karbre » Sat May 08, 2021 12:13 pm
Okay then, I guess the MKV as it came out of MakeMKV is as good as the one processed with MKVToolNix, as the DV data is not altered. I'm not planning on converting to other DV profiles.
Turning SDH subtitles into non-SDH subtitles is the one thing I regularly do but can't be done with MakeMKV, only via extracting the subtitle file, processing it with SubtitleEdit, and then muxing it back in. Most other stuff can probably be done with MakeMKV, yes, although I'm not sure if e.g. changing the order of audio tracks is possible.
Bigboypants
Post by Bigboypants » Sun May 09, 2021 11:05 am
Can UBX700 read makemkv raw backups and output dolby vision?
if not then how can I use an MKV backup to playback DV?
ultrahorst
Post by ultrahorst » Sun May 09, 2021 9:52 pm
Actually, this is not true for the latest MKVToolNix version: https://gitlab.com/mbunkus/mkvtoolnix/-/issues/3093
Just a heads up, users in other forums reported that MKVs created with versions 56.0.0 and 56.1.0 without the program argument
--engage dont_normalize_parameter_sets
do not work in some players, and re-muxing with a lower version or the program arguments mentioned in the linked issue does not work.
ooofz
Post by ooofz » Mon May 10, 2021 2:29 am
EDIT:
MP4 DV movies with FEL are playing very dark on my CX also (and other users reported the same in this thread if i remember correctly).
Titles with MEL are playing fine though and therefore unfortunately the only solution i found, was to convert the FEL to MEL (but probably any way discarding the extra data for reconstructing the original 12-bit signal and only keeping the RPU should be sufficient).
I think MakeMKV is showing if EL is Full or Minimal, or just check e.g. here: https://forum.blu-ray.com/showthread.php?t=276448
For messing around with ELs/RPU best experience for me was with quietvoid's tool: https://github.com/quietvoid/dovi_tool (thanks very much for your effort from a mostly only reading user on this way ;) keep up the good work!)
