Ripping Flash Gordon (Again)
arrbee99
Post by arrbee99 » Sat May 01, 2021 11:56 pm
Have been having trouble ripping the 4K Flash Gordon, bought in New Zealand if it matters. After trying and failing and getting lots of scsi errors, giving the disc a (gentle) clean, shutting the PC down completely and restarting, I tried unchecking the decrypt box and seem to have copied the whole thing to disc. Its about 70gig. Question now is, what do I do to try to decrypt the copy on disc (well SSD actually). What MakeMKV command do I use and what do I point it to in the copied folder ?
Didn't spot anything googling even though I guess the answer is really obvious (though not to me of course...)
Thanks very much.
Re: Ripping Flash Gordon (Again)
Post by dcoke22 » Sun May 02, 2021 2:43 am
After MakeMKV starts, do File -> Open files and point it at the file(s).
arrbee99
Post by arrbee99 » Sun May 02, 2021 2:59 am
Thanks I tried that but you made me realise that I hadn't pointed MakeMKV to the discatt.dat file, which does seem to work.
Now I get to see what happens with the copy on disk not being decrypted...
arrbee99
Post by arrbee99 » Sun May 02, 2021 3:13 am
...and that seems to have worked just fine. Thanks very much.
