MakeMKV Will Not Read BDMV Files Now! Anyone else?
Tails
Application doesn't identify index.bdmv files anymore
Post by Tails »
This started with the version 1.6.4. Application doesn't recognize index.bdmv files are correct blu ray files anymore.
cybersonik
Not able to open .IFO in 1.6.4
Post by cybersonik »
In MakeMKV 1.6.3, I navigate to a VIDEO_TS folder from an already ripped disc and open the .IFO, after which MakeMKV does its thing. In MakeMKV 1.6.4, I am not able to select an IFO anymore - which in turn prevents me from converting to mkv. Am I missing something?
carmatana
Re: Not able to open .IFO in 1.6.4
Post by carmatana »
Same problem here, .ISO files are disabled and cannot be selected.
dmal99
Post by dmal99 »
I don't know what happened but suddenly after upgrade MakeMKV refuses to recognize BDMV files and they are always grayed out.
anyone else?
aspen2k
Re: Application doesn't identify index.bdmv files anymore
Post by aspen2k »
I can confirm the problem. Neither Blue-Ray index files nor DVD index files are recognized anymore. Please fix!
aspen2k
Re: MakeMKV Will Not Read BDMV Files Now! Anyone else?
Post by aspen2k »
yes, same for me
aspen2k
Post by aspen2k »
same problem here
cybersonik
Romansh
Post by Romansh »
Same here. And of course 1.6.3 refuses to launch now.
woodmeister
Post by woodmeister »
I have also seen the same issue where BD type files not recognized.
Currently running OSX10.6.6,64 bit.
crowfax
Post by crowfax »
Tiluap
Post by Tiluap »
Same o Same o with me. IFO is not on active / selectable mode.
RyeGuyWpg
Post by RyeGuyWpg »
+1. 1.6.3 just expired, I installed 1.6.4 and can't open any .iso files to rip. Tried installing the DASPI package just to see if that made a difference and it didn't.
jdthird
Post by jdthird »
Same problem here, also installed dsapi just in case that was a requirement.
IFO files not selectable at all.
Also tells me it can't find any usable optical drives - is that because I installed the dsapi component, or simply because I don't have any media physically in the drive? I never saw this in the previous versions even without a disc in the drive. On a new macbook pro i5.
Edit - removed daspi and now it shows my MBPs optical drive again as available, no more "can't find any usable optical drive" message.
No joy with IFO's though, whether opening from the GUI or just trying to drag and drop things onto the program.
Post by mike admin »
This is a bug in new UI, fix coming shortly.
