Bionic71
#1
Post
by Bionic71 » Sat Feb 05, 2011 7:00 pm
Hi Mike, I've updated today and I'm getting this when exiting MakeMKV
Setup_MakeMKV_v1.6.4 (Win7 x64)
jriddle
#2
Post
by jriddle » Sat Feb 05, 2011 9:27 pm
Bionic71 wrote:Hi Mike, I've updated today and I'm getting this when exiting MakeMKV
I updated today with the exact same error message.............. Does this effect function of the program?
BTW: I'm also running Win7 x64 Ultimate.
John
crowfax
#3
Post
by crowfax » Sun Feb 06, 2011 3:22 am
I installed on my windows machine and am also able to replicate the issue.
Win 7 x64 Home Premium.
dtblair
#5
Post
by dtblair » Sun Feb 06, 2011 4:40 pm
I get the same error on both Windows XP and 7
thurmma
#6
Post
by thurmma » Sun Feb 06, 2011 9:54 pm
I hope this helps someone. I had the same error and it wouldn't find my dvd drive, so I reinstalled using the "Run as Administrator" option and everything appears to be working just fine for me now.
I am running 2008 Small Business Server x64 on a dual xeon 3.2ghz with 6 gig ram.
markb
#7
Post
by markb » Mon Feb 07, 2011 4:37 am
Same error here...Both Win7x32 and Win7x64.
setarip_old
#8
Post
by setarip_old » Mon Feb 07, 2011 6:49 am
On my Vista 64bit system, after exiting the program and then after a second or two more, I receive the same error message. It appears to be harmless...
ptr727
#9
Post
by ptr727 » Mon Feb 07, 2011 8:26 pm
Same problem, error dialog shows when exiting app.
amenhotep
#10
Post
by amenhotep » Tue Feb 08, 2011 7:47 am
I'm getting the same fatal error message at exit. I'm running Windows 7 Home Premium, 32-bit.
I also discovered I could not select ripped DVDs on my hard drive to convert to mkv. Using the MakeMKV file menu option pulls up a Windows Explorer window that shows NO FILES under any ripped dvd folder. This was true no matter which filter was selected. However, when I opened Windows Explorer directly the files were clearly there.
The Windows Explorer that opens up from the 1.6.4 file menu also has the Files and Folders Option greyed out, so you can't force it to show hidden files.
Yesterday I uninstalled 1.6.4 and re-installed 1.6.3. The inability to show or select any ripped DVD files continued. This evening I tried again and now .IFO files will show.
amenhotep
#11
Post
by amenhotep » Tue Feb 08, 2011 9:33 pm
amenhotep wrote:I'm getting the same fatal error message at exit. I'm running Windows 7 Home Premium, 32-bit.
Addendum to my earlier post:
Tried again today - back to the problem where opening file menu doesn't show any files to select to convert to mkv.
WCVanHorne
#12
Post
by WCVanHorne » Thu Feb 10, 2011 4:30 am
Ditto here. WinXP. Doesn't seem to do it if I let it "rest" a while before shutting down with no disc in the drive.
Definitely something new. MakeMKV has previously been rock solid for me.
Post
by mike admin » Thu Feb 10, 2011 9:02 am
Confirmed as a "harmless" error, will be fixed very soon.
