Cannot select bdmv/IFO files with 1.6.4 and Snow Leopard
DrPaul
Post by DrPaul » Sun Feb 06, 2011 6:26 am
I have ripped my DVDs and Blu-Rays to the file system and I am repackaging them as MKV files.
No files can be selected with the new version so I cannot convert anything.
Ripping directly from the Blu-ray drive does work. Although I do not seem to be able to select/deselect titles with the space bar anymore.
This is on an iMac 27" i7 8GB RAM 1TB running 10.6.6 and a registered version of MakeMKV.
The same setup is working fine in 1.6.3.
Re: Cannot select bdmv/IFO files with 1.6.4 and Snow Leopard
Post by mike admin » Sun Feb 06, 2011 10:38 am
It's a bug. A price for the new shiny interface :(
aspen2k
Post by aspen2k » Sun Feb 06, 2011 12:48 pm
when will this bug be fixed?
gondovald
Post by gondovald » Sun Feb 06, 2011 4:17 pm
Yeah,
Cannot convert DVD's anymore....
Can't wait for correction ...
Post by mike admin » Tue Feb 08, 2011 9:23 am
Should be fixed in a few days. There is no workaround other than using previous version.
vainlord
Post by vainlord » Fri Feb 11, 2011 2:35 pm
So where can i download a "previous" version that works ?
Thanx!
crowfax
Post by crowfax » Fri Feb 11, 2011 6:50 pm
vainlord
Post by vainlord » Sat Feb 12, 2011 8:17 pm
Sadly older version can't run unless you register ? I can't find a way to do that ? Or even buy a license ?
vainlord
Post by vainlord » Sat Feb 12, 2011 9:14 pm
Ok found out how to buy it, and now i can use the older version. Much appreciated !
