Community Blu Ray - AV Sync Error not saving titles
minkiz88
Post by minkiz88 »
I'm just on the first disc, it failed to save 2 episodes. There were hundreds of messages, so the gaps here are from me deleting dozens of seemingly duplicate errors. All the other episodes ripped fine, and even a couple movies I ripped before this. I also took the disc out and cleaned it, though on inspection it look perfect.
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321664000-2321670144, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321670144, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321670144-2321676288, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321676288, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323120128-2323126272, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323126272, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323126272-2323132416, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323132416, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323132416-2323138560, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323138560, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323138560-2323144704, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323144704, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323144704-2323150848, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323150848, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323150848-2323156992, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323156992, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323156992-2323163136, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323163136, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323163136-2323169280, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323169280, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323279872, attempting to work around
Hash check failed for file 00020.m2ts at offset 2364991488, file is corrupt.
Hash check failed for file 00020.m2ts at offset 2365188096, file is corrupt.
Too many hash check errors in file 00020.m2ts.
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2366091264, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2366109696, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2366109696-2366121984, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2366121984-2366134272, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2366152704, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321608704, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321608704-2321614848, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321614848, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321614848-2321620992, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321620992, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321620992-2321627136, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321627136, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321627136-2321633280, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321633280, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321633280-2321639424, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321639424, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321639424-2321645568, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321645568, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321645568-2321651712, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321651712, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321651712-2321657856, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321657856, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321657856-2321664000, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2321664000, attempting to work around
The source file '/BDMV/STREAM/00020.m2ts' is corrupt or invalid at offset 2323120128, attempting to work around
Failed to save title 8 to file X:/!RIPPED MOVIES/title_t08.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 10 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 2 failed
Re: Community Blu Ray - AV Sync Error not saving titles
viewtopic.php?f=8&t=15055
That's a post about errors during ripping.
The short version is, the optical drive was unable to correctly read the disc. Gently clean the disc and try again.
minkiz88
Post by minkiz88 »
I did so, to no avail. I'd say the disc was brand new, but I see the latter part of number 1, so maybe that's the issue? I'll wipe it down again and give it a try.
