Attempting to flash in macOS
Re: Attempting to flash in macOS
#46 Post by Billycar11 » Thu Apr 22, 2021 1:02 am
Nshawn wrote: Thu Apr 22, 2021 12:51 am
Billycar11 wrote: Thu Apr 22, 2021 12:47 am
Nshawn wrote: Thu Apr 22, 2021 12:46 am Attempting flash my wH16NS40 and getting this error. Here is what I had in terminal. Any suggestions? Thanks in advance
Thes-MBP:MacOS Shawn$ ./makemkvcon f -d /IOBDServices/65E3835A -f ~/Applications/MakeMKV.app/Contents/MacOS/sdf.bin rawflash main,enc -i ~/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ 5.25\ desktop/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Unable to load sdf.bin
Internal error 0xffffffff
what usb adapter are you using?
NST536S3
i see that should work for flashing but i see the amazon says its been updated i hope they didnt remove the flashing ability when you bought it did it say updated?
Nshawn
#47 Post by Nshawn » Thu Apr 22, 2021 1:42 am
Billycar11 wrote: Thu Apr 22, 2021 1:02 am
NST536S3
Yea, it said updated. Guess lll be returning that one. Is there a different one you recommend?
#48 Post by Billycar11 » Thu Apr 22, 2021 1:51 am
Nshawn wrote: Thu Apr 22, 2021 1:42 am
NST536S3
hmm im not 100% sure its really just a idea.
you could go with the owc one
not 100% sure it will fix your issue
you might want to try in boot camp to rule the case out as a problem
Nshawn
#49 Post by Nshawn » Thu Apr 22, 2021 2:17 am
Billycar11 wrote: Thu Apr 22, 2021 1:51 am
Ok, I'll get back once I try. Do you know why makemkv.com is being blocked? All I get is a page in Russian.
#50 Post by Billycar11 » Thu Apr 22, 2021 6:56 am
Nshawn wrote: Thu Apr 22, 2021 2:17 am
not sure hopefully something simple like data cap reached
Nshawn
#51 Post by Nshawn » Sat Apr 24, 2021 12:13 pm
Billycar11 wrote: Thu Apr 22, 2021 6:56 am
With the server down is there somewhere else I can get the sdf.bin file? Is it the same as when I extract appdata.tar and find the sdf_0000007e.bin? Can I use that instead of sdf.bin?
#52 Post by Billycar11 » Sat Apr 24, 2021 8:39 pm
Just move private data .tar from your mac to pc
Nshawn
#53 Post by Nshawn » Sun Apr 25, 2021 12:00 am
Billycar11 wrote: Sat Apr 24, 2021 8:39 pm Just move private data .tar from your mac to pc
The only .tar file I have is appdata.tar in the resources folder. if I extract it I get sdf_0000007e.bin, can I use that instead of sdf.bin in my command line flash using the makemkv flasher?
#54 Post by Billycar11 » Sun Apr 25, 2021 12:05 am
Nshawn wrote: Sun Apr 25, 2021 12:00 am
yeah just rename it to sdf.bin and put it in the makemkv data directory open makemkv if it disappears it worked then try to flash
Nshawn
#55 Post by Nshawn » Sun Apr 25, 2021 10:05 pm
Billycar11 wrote: Sun Apr 25, 2021 12:05 am
So it worked! I extracted the appdata.tar file to get the sdf_0000007e.bin file, moved it my desktop and renamed it sdf.bin. I used that in the command line to flash the WH16NS60 1.02 MK firmware on my Mac without using boot camp. I wonder if since the makemkv.com site is down it was not able to get the sdf.bin file right. Who knows. I have yet to test it on a UHD disc, only regular bluray, but makemkv says it is Libre drive enabled and that it is a WH16NS60 running 1.02.
So now I can use the same method, without the ENC part since it is no longer encrypted, to put on DE firmware from WH16NS60 or WH16NS40 if I wish. Correct?
#56 Post by Billycar11 » Sun Apr 25, 2021 10:21 pm
Nshawn wrote: Sun Apr 25, 2021 10:05 pm
you could but not reason and WH16ns40 is worse firmware
runnernorth
#57 Post by runnernorth » Sat Jan 29, 2022 10:09 pm
j_dot wrote: Wed Oct 07, 2020 12:22 am Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
Start by navigating to the MakeMKV application
cd /Applications/MakeMKV.app/Contents/MacOS
Get the latest SDF file; write it to the local directory (you can also write it to your home directory or someplace more convenient)
curl -O "https://makemkv.com/sdf.bin"
Find the drive identifiers
./makemkvcon f --list
Look for your drive. You should see something like this (in this example, I have two drives attached, each with a disc in; as the first post in the thread points out, though, the /dev/rdisk* won't work):
Found 2 drives(s)
00: /IOBDServices/65961856, /dev/rdisk2, /dev/rdisk2
  PIONEER_BD-RW___BDR-212U_1.00_SFDL000221WL
01: /IOBDServices/C01417F1, /dev/rdisk5, /dev/rdisk5
  HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLFK7LA5541
I was looking to flash the WH16NS60, and I had downloaded the latest MK firmware pack, so:
./makemkvcon f -d /IOBDServices/C01417F1 -f sdf.bin rawflash main,enc -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Note that I needed to use enc because the 1.03 firmware is encrypted; leave that off if your current firmware is unencrypted.
After doing this, and turning my drive off and on just in case, I was able to rip from a UHD disc. (And, for faster reads: https://www.makemkv.com/forum/viewtopic.php?p=93341 )
Hi; I'm trying to follow these steps for flashing my LG UHD drive in Mac os, but how do I see if the firmware is encrypted?- think I've read somewhere, that firmware with the date within 2020 is encrypted, thus mine is not encrypted, or what ??
Product: BD-RE BH16NS55
Revision: 1.05
Serial number: KLSL1PI5802
Firmware date: 2120-06-18 13:42
Highest AACS version: 76
#58 Post by Billycar11 » Sat Jan 29, 2022 10:31 pm
runnernorth wrote: Sat Jan 29, 2022 10:09 pm
Found 2 drives(s)
Revision: 1.05
You look at the guide linked below at the know encrypted list
theaterbyte
#59 Post by theaterbyte » Tue May 03, 2022 3:26 pm
o-ver wrote: Thu May 28, 2020 5:03 pm Big Thanks to MacOS (and a deep, deep bow to mike admin!) I successfully flashed my slim device Buffalo (manufactur. date: 2019.10.30 from https://conrad.de in MacOS High Sierra with Libre Drive enabled Firmware HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin.
Before I got this new slim Buffalo, I tried devices from ASUS and Verbatim (all slim). The Buffalo with LibreDrive Firmware rips my Test BD with 4.2 - 4.6x :shock: vs. the 1.8 - 2.0x :cry: with ASUS and Verbatim. Really satisfying!
It took quiet some time to understand sdftool and SDF.bin and fiddle with all aspects of command line, drives and flashing in MacOS.
What I did:
  • Put the right firmware in home directory
  • Extraction of sdf_0000006d.bin to my home directory
    cp /Applications/MakeMKV.app/Contents/Resources/appdata.tar ~
    tar -xvf appdata.tar sdf_0000006d.bin
  • Gathering name of device (as User MacOS showed us). In my case there is a good old internal RPC1 (thx2 XVI!) DVD Apple SuperDrive in first order, the second one is the Buffalo
    /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -l
    00: IODVDServices:XXXXXXXXXXXXXXXX:MATSHITA DVD-R   UJ-8A8 HA13
      MATSHITA_DVD-R___UJ-8A8_HA13_K83
    01: IOBDServices:XXXXXXXXXXXXXXXX:BUFFALO Optical Drive BN12
      BUFFALO_Optical_Drive_BN12_211905141415_MO1J93A2324
  • Now, Flashing...
    Sending flash image to drive took a few seconds, programming flash was about 30 sec
    /Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d 'IOBDServices:XXXXXXXXXXXXXXXX:BUFFALO Optical Drive BN12' -f sdf_0000006d.bin rawflash main -i HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin
    Reading input file HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin
    yes
     100% Operation finished
    Done successfully
Unfortunately, I was not able to figure out, how to flash the drive with the "drive-id". I tried it several times but to no avail.
PLEASE continue your amazing work and contributions (mike admin and all of you out there) & please users register makemkv, so this thing goes on!
o-ver
I have gone through the terminal process trying to flash the firmware on the Archgon and gotten all the way to the end, with it telling me 100% Operation finished Done Successfully. Yet, when I launch MakeMKV the drive still shows the original firmware and cannot rip UHD discs. I am incredibly puzzled.
#60 Post by Billycar11 » Tue May 03, 2022 9:26 pm
theaterbyte wrote: Tue May 03, 2022 3:26 pm I have gone through the terminal process trying to flash the firmware on the Archgon and gotten all the way to the end, with it telling me 100% Operation finished Done Successfully. Yet, when I launch MakeMKV the drive still shows the original firmware and cannot rip UHD discs. I am incredibly puzzled.
What's your makemkv drive info
And tell me the command your typing in
