i see that should work for flashing but i see the amazon says its been updated i hope they didnt remove the flashing ability when you bought it did it say updated?Nshawn wrote: Thu Apr 22, 2021 12:51 amNST536S3Billycar11 wrote: Thu Apr 22, 2021 12:47 amwhat usb adapter are you using?Nshawn wrote: Thu Apr 22, 2021 12:46 am Attempting flash my wH16NS40 and getting this error. Here is what I had in terminal. Any suggestions? Thanks in advance
Thes-MBP:MacOS Shawn$ ./makemkvcon f -d /IOBDServices/65E3835A -f ~/Applications/MakeMKV.app/Contents/MacOS/sdf.bin rawflash main,enc -i ~/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ 5.25\ desktop/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Unable to load sdf.bin
Internal error 0xffffffff
Attempting to flash in macOS
Re: Attempting to flash in macOS
Yea, it said updated. Guess lll be returning that one. Is there a different one you recommend?Billycar11 wrote: Thu Apr 22, 2021 1:02 ami see that should work for flashing but i see the amazon says its been updated i hope they didnt remove the flashing ability when you bought it did it say updated?
hmm im not 100% sure its really just a idea.Nshawn wrote: Thu Apr 22, 2021 1:42 amYea, it said updated. Guess lll be returning that one. Is there a different one you recommend?Billycar11 wrote: Thu Apr 22, 2021 1:02 ami see that should work for flashing but i see the amazon says its been updated i hope they didnt remove the flashing ability when you bought it did it say updated?
you could go with the owc one
not 100% sure it will fix your issue
you might want to try in boot camp to rule the case out as a problem
Ok, I'll get back once I try. Do you know why makemkv.com is being blocked? All I get is a page in Russian.Billycar11 wrote: Thu Apr 22, 2021 1:51 amhmm im not 100% sure its really just a idea.Nshawn wrote: Thu Apr 22, 2021 1:42 amYea, it said updated. Guess lll be returning that one. Is there a different one you recommend?Billycar11 wrote: Thu Apr 22, 2021 1:02 am
not sure hopefully something simple like data cap reachedNshawn wrote: Thu Apr 22, 2021 2:17 amOk, I'll get back once I try. Do you know why makemkv.com is being blocked? All I get is a page in Russian.Billycar11 wrote: Thu Apr 22, 2021 1:51 amhmm im not 100% sure its really just a idea.Nshawn wrote: Thu Apr 22, 2021 1:42 am
With the server down is there somewhere else I can get the sdf.bin file? Is it the same as when I extract appdata.tar and find the sdf_0000007e.bin? Can I use that instead of sdf.bin?Billycar11 wrote: Thu Apr 22, 2021 6:56 amnot sure hopefully something simple like data cap reachedNshawn wrote: Thu Apr 22, 2021 2:17 amOk, I'll get back once I try. Do you know why makemkv.com is being blocked? All I get is a page in Russian.Billycar11 wrote: Thu Apr 22, 2021 1:51 am
Just move private data .tar from your mac to pc
The only .tar file I have is appdata.tar in the resources folder. if I extract it I get sdf_0000007e.bin, can I use that instead of sdf.bin in my command line flash using the makemkv flasher?
yeah just rename it to sdf.bin and put it in the makemkv data directory open makemkv if it disappears it worked then try to flashNshawn wrote: Sun Apr 25, 2021 12:00 amThe only .tar file I have is appdata.tar in the resources folder. if I extract it I get sdf_0000007e.bin, can I use that instead of sdf.bin in my command line flash using the makemkv flasher?
So it worked! I extracted the appdata.tar file to get the sdf_0000007e.bin file, moved it my desktop and renamed it sdf.bin. I used that in the command line to flash the WH16NS60 1.02 MK firmware on my Mac without using boot camp. I wonder if since the makemkv.com site is down it was not able to get the sdf.bin file right. Who knows. I have yet to test it on a UHD disc, only regular bluray, but makemkv says it is Libre drive enabled and that it is a WH16NS60 running 1.02.Billycar11 wrote: Sun Apr 25, 2021 12:05 amyeah just rename it to sdf.bin and put it in the makemkv data directory open makemkv if it disappears it worked then try to flashNshawn wrote: Sun Apr 25, 2021 12:00 amThe only .tar file I have is appdata.tar in the resources folder. if I extract it I get sdf_0000007e.bin, can I use that instead of sdf.bin in my command line flash using the makemkv flasher?
So now I can use the same method, without the ENC part since it is no longer encrypted, to put on DE firmware from WH16NS60 or WH16NS40 if I wish. Correct?
you could but not reason and WH16ns40 is worse firmwareNshawn wrote: Sun Apr 25, 2021 10:05 pmSo it worked! I extracted the appdata.tar file to get the sdf_0000007e.bin file, moved it my desktop and renamed it sdf.bin. I used that in the command line to flash the WH16NS60 1.02 MK firmware on my Mac without using boot camp. I wonder if since the makemkv.com site is down it was not able to get the sdf.bin file right. Who knows. I have yet to test it on a UHD disc, only regular bluray, but makemkv says it is Libre drive enabled and that it is a WH16NS60 running 1.02.Billycar11 wrote: Sun Apr 25, 2021 12:05 amyeah just rename it to sdf.bin and put it in the makemkv data directory open makemkv if it disappears it worked then try to flashNshawn wrote: Sun Apr 25, 2021 12:00 am
runnernorth
Hi; I'm trying to follow these steps for flashing my LG UHD drive in Mac os, but how do I see if the firmware is encrypted?- think I've read somewhere, that firmware with the date within 2020 is encrypted, thus mine is not encrypted, or what ??j_dot wrote: Wed Oct 07, 2020 12:22 am Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
Start by navigating to the MakeMKV applicationGet the latest SDF file; write it to the local directory (you can also write it to your home directory or someplace more convenient)Code: Select all
cd /Applications/MakeMKV.app/Contents/MacOSFind the drive identifiersCode: Select all
curl -O "https://makemkv.com/sdf.bin"Look for your drive. You should see something like this (in this example, I have two drives attached, each with a disc in; as the first post in the thread points out, though, the /dev/rdisk* won't work):Code: Select all
./makemkvcon f --list
I was looking to flash the WH16NS60, and I had downloaded the latest MK firmware pack, so:Code: Select all
Found 2 drives(s) 00: /IOBDServices/65961856, /dev/rdisk2, /dev/rdisk2 PIONEER_BD-RW___BDR-212U_1.00_SFDL000221WL 01: /IOBDServices/C01417F1, /dev/rdisk5, /dev/rdisk5 HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLFK7LA5541
Note that I needed to use enc because the 1.03 firmware is encrypted; leave that off if your current firmware is unencrypted.Code: Select all
./makemkvcon f -d /IOBDServices/C01417F1 -f sdf.bin rawflash main,enc -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
After doing this, and turning my drive off and on just in case, I was able to rip from a UHD disc. (And, for faster reads: https://www.makemkv.com/forum/viewtopic.php?p=93341 )
Product: BD-RE BH16NS55
Revision: 1.05
Serial number: KLSL1PI5802
Firmware date: 2120-06-18 13:42
Highest AACS version: 76
You look at the guide linked below at the know encrypted listrunnernorth wrote: Sat Jan 29, 2022 10:09 pmHi; I'm trying to follow these steps for flashing my LG UHD drive in Mac os, but how do I see if the firmware is encrypted?- think I've read somewhere, that firmware with the date within 2020 is encrypted, thus mine is not encrypted, or what ??j_dot wrote: Wed Oct 07, 2020 12:22 am Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
Revision: 1.05
theaterbyte
I have gone through the terminal process trying to flash the firmware on the Archgon and gotten all the way to the end, with it telling me 100% Operation finished Done Successfully. Yet, when I launch MakeMKV the drive still shows the original firmware and cannot rip UHD discs. I am incredibly puzzled.o-ver wrote: Thu May 28, 2020 5:03 pm Big Thanks to MacOS (and a deep, deep bow to mike admin!) I successfully flashed my slim device Buffalo (manufactur. date: 2019.10.30 from https://conrad.de in MacOS High Sierra with Libre Drive enabled Firmware HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin.
Before I got this new slim Buffalo, I tried devices from ASUS and Verbatim (all slim). The Buffalo with LibreDrive Firmware rips my Test BD with 4.2 - 4.6xvs. the 1.8 - 2.0x
with ASUS and Verbatim. Really satisfying!
It took quiet some time to understand sdftool and SDF.bin and fiddle with all aspects of command line, drives and flashing in MacOS.
What I did:
- Put the right firmware in home directory
- Extraction of sdf_0000006d.bin to my home directory
cp /Applications/MakeMKV.app/Contents/Resources/appdata.tar ~ tar -xvf appdata.tar sdf_0000006d.bin
- Gathering name of device (as User MacOS showed us). In my case there is a good old internal RPC1 (thx2 XVI!) DVD Apple SuperDrive in first order, the second one is the Buffalo
/Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -l 00: IODVDServices:XXXXXXXXXXXXXXXX:MATSHITA DVD-R UJ-8A8 HA13 MATSHITA_DVD-R___UJ-8A8_HA13_K83 01: IOBDServices:XXXXXXXXXXXXXXXX:BUFFALO Optical Drive BN12 BUFFALO_Optical_Drive_BN12_211905141415_MO1J93A2324Unfortunately, I was not able to figure out, how to flash the drive with the "drive-id". I tried it several times but to no avail.
- Now, Flashing...
Sending flash image to drive took a few seconds, programming flash was about 30 secCode: Select all
/Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d 'IOBDServices:XXXXXXXXXXXXXXXX:BUFFALO Optical Drive BN12' -f sdf_0000006d.bin rawflash main -i HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin Reading input file HL-DT-ST-BD-RE_BU40N-BN12-0M01001-211905141415.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Ready to write drive flash memory. Type "yes" to continue, "no" to abort yes Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully
PLEASE continue your amazing work and contributions (mike admin and all of you out there) & please users register makemkv, so this thing goes on!
o-ver
What's your makemkv drive infotheaterbyte wrote: Tue May 03, 2022 3:26 pm I have gone through the terminal process trying to flash the firmware on the Archgon and gotten all the way to the end, with it telling me 100% Operation finished Done Successfully. Yet, when I launch MakeMKV the drive still shows the original firmware and cannot rip UHD discs. I am incredibly puzzled.
And tell me the command your typing in
