BP60NB10 Firmware Downgrade Error
Ventriloquist
Re: BP60NB10 Firmware Downgrade Error
Weekbump: Any luck with the test flash image?
Here you go!
Ventriloquist
Thanks, mike. Ripping a test disc now.
Let me know if there's anything in particular you need tested with the image.
Can you please confirm if the new 1.01-MK is UHD friendly or if a downgrade to 1.00 is required.Ventriloquist wrote: Fri Feb 14, 2020 10:01 pm Thanks, mike. Ripping a test disc now.
Ventriloquist
No downgrade appears to be required. (Mike didn't instruct me to, I didn't try. He's updated the firmware pack to include the 1.01-MK image as well.)
I'm on my 3rd UHD rip as I post this.
Thanks for the confirmation!Ventriloquist wrote: Sat Feb 15, 2020 2:00 am No downgrade appears to be required. (Mike didn't instruct me to, I didn't try. He's updated the firmware pack to include the 1.01-MK image as well.)
copperjr
Hi Mike. I have tried everything. I have the LG External BP60NB10 and everytime i try to run the asus odd FW i get the error after it ejects. help!
Don't use the ASUS flasher. Use the newer SDFtool Flasher. Also, if your drive is new and has encrypted firmware 1.02, check "enc?" for the first flash.copperjr wrote: Tue Apr 20, 2021 12:02 amHi Mike. I have tried everything. I have the LG External BP60NB10 and everytime i try to run the asus odd FW i get the error after it ejects. help!
1. If it has 1.02, flash 1.02-MK with enc checked. If it has 1.01, flash 1.01-MK without enc.
2. Flash 1.00-MK without enc.
