userr
Post by userr » Sat Apr 17, 2021 3:53 pm
RESET_9999 wrote: Fri Apr 09, 2021 1:17 am Just got a Chromecast, and I confirm that it's a FEL DV capable device. The ending credits of Power rangers is bright white... FEL noise visible on test file as confirmed before. great player for my bedroom TV :)
player-led and tv-led seem to be behaving strangely ... on my C8 OLED I'm only getting LLDV(player-led) but on my cheap Vizio TV which doesn't support LLDV I get TV-led DV. HDR10 and SDR are color accurate.
*tested iTunes, Movies Anywhere, and PLEX
also, no red push in the Dr. Sleep p7 rip. The Shield is really the only device that has color issues and yet, the nvidia staff still say that they don't see any difference :lol: ...
very interesting, still satisfied with it?
edit: i havent been paying attention for a good while. Last time i was reading here, we really didnt know if FEL was even displayed correctly on 2019 shield, any news on that?
Im asking you because i know you are know much about this DV subject :)
norrellmeister
Post by norrellmeister » Sat Apr 17, 2021 11:16 pm
Spent some time with the Chromecast Google TV today with Plex. I confirmed that FEL is playing, as expected. Some mkv remuxes don’t seem to DV at all without manually switching audio tracks, because they start to direct stream instead of direct play due to audio codec limitations, and on this device that breaks DV. When DV does work, audio is often showing up as multichannel PCM on the receiver, as expected based on other posts here. Image quality looks really good, probably better than the Shield. I did see one situation where audio and video got out of sync, and one situation where the FEL layer was playing just slightly out of sync. This was visible as ghosting in Power Rangers white credits. Seeking in the video fixed that up quickly.
One more thing: stability is overall better than Ugoos, but I am seeing issues where if I switch sway from Plex, the video goes to HDR mode instead of DV. Restarting the video fixes it. Not perfect, but likely better than the Shield for my purposes, for P7 files.
The device was set to 24p manually, since it has no auto frame rate switching.
userr
Post by userr » Sun Apr 18, 2021 2:33 pm
norrellmeister wrote: Sat Apr 17, 2021 11:16 pm Spent some time with the Chromecast Google TV today with Plex. I confirmed that FEL is playing, as expected. Some mkv remuxes don’t seem to DV at all without manually switching audio tracks, because they start to direct stream instead of direct play due to audio codec limitations, and on this device that breaks DV. When DV does work, audio is often showing up as multichannel PCM on the receiver, as expected based on other posts here. Image quality looks really good, probably better than the Shield. I did see one situation where audio and video got out of sync, and one situation where the FEL layer was playing just slightly out of sync. This was visible as ghosting in Power Rangers white credits. Seeking in the video fixed that up quickly.
doesnt the plex app itself have framerate switching tho?
psychoboust
Post by psychoboust » Mon Apr 19, 2021 10:34 am
Do you think some new 2021 TV with the last Android TV version will be able to run some MP4 or MKV DV profile directly from the TV without any external box ?
I was looking for a new TV and wonder if it will be possible to get that without my Shield Pro...
chros
Post by chros » Mon Apr 19, 2021 8:11 pm
RESET_9999 wrote: Fri Apr 09, 2021 5:30 pm
chros wrote: Fri Apr 09, 2021 3:32 pm
I've added the B8 DoVi graphs into the post above.
so since my TV use maxcll (or MDL when no maxcll) and because maxcll is not very reliable(often incorrect), is it better to use madvr ''output in hdr'' with peak set to 700nits? what do you use ?
Come over the doom9 LG Oled with madvr thread we can talk about it more there.
DaMacFunkin
Post by DaMacFunkin » Tue Apr 20, 2021 4:43 am
userr wrote: Sun Apr 18, 2021 2:33 pm
When I had the CCwGTV no app would switch the refresh rate, not even Plex, it needed to be done in settings which lead me to believe frame rate switching isn’t supported on the device, I even tried the refresh rate app from the shield but it wouldn’t run.
mulucy
Post by mulucy » Sat Apr 24, 2021 6:16 pm
What's happening with the main website?
Epedemic
Post by Epedemic » Sat Apr 24, 2021 9:35 pm
mulucy wrote: Sat Apr 24, 2021 6:16 pm What's happening with the main website?
Good question, seems like missing payment on hosting (or the hosting providers hosting), but that's just speculation.
Epedemic
Post by Epedemic » Sat Apr 24, 2021 9:41 pm
So, i've about had it with the shield... the ugoos seems dead on arrival.... the oppo 203 is too damn expensive.... the chinoppo seems dodgy at best (and is also too expensive..... and the cc with google tv dosen't do lossless... That pretty much leaves me with the option of the X700... Correct?
Also, if i go down this path: is it possible to convert my .mkv library (with DV) back to bdmv folder structure, or do i need to rerip (or... ew... play discs)?
Post by shawnc22 » Sat Apr 24, 2021 10:14 pm
Epedemic wrote: Sat Apr 24, 2021 9:41 pm So, i've about had it with the shield... the ugoos seems dead on arrival.... the oppo 203 is too damn expensive.... the chinoppo seems dodgy at best (and is also too expensive..... and the cc with google tv dosen't do lossless... That pretty much leaves me with the option of the X700... Correct?
What've you heard about the chinoppo being dodgy? I finally the took the plunge and got one last month, and it's been great so far. It plays all my full disks DV backups without issue. There're some simple things you can do like auto mount your network shares that makes browsing your collection pretty easy.
As for the x700, you're gonna have to demux your .mkv DV library back into 2 separate video tracks with yusecope's tool and then remux it into a ts/m2ts container for the x700.
mulucy
Post by mulucy » Sun Apr 25, 2021 1:04 am
Don't want to be bad news, but I would not invest too much in FEL capable players. Most studios are gonna exit the physical disk market sooner or later. I heard rumors about WB exiting the market soon and focusing completely on streaming instead with HBO Max.
To answer your question, you will have to use Sony X700. I wish Chromecast with Google TV did support the lossless audio, it would have been an ultimate streaming player! Have you tried importing the MKV files in Tsmuxer and demuxing from there?
GYTcool
Post by GYTcool » Sun Apr 25, 2021 3:23 pm
yusesope wrote: Thu Sep 17, 2020 2:59 pm Good afternoon everyone.
The weekend is approaching so it seemed appropriate to me to release something for you to play with.
Thank you for your tutorial!I can now play Dolby Vision MKV files successfully, but I found a bug about the Exoplayer, that is… the embedded subtitles in the black edge cannot be displayed, this only happens when playing Dolby Vision MKV files.
XTrojan
Post by XTrojan » Mon Apr 26, 2021 4:30 pm
mulucy wrote: Sun Apr 25, 2021 1:04 am
I agree! But the fact that top end players like Nvidia Shield Pro can't accurately present DV (without FEL) makes me severely annoyed, i've somewhat given up on DV for now and just playback standard HDR10.
bobbymkV
Post by bobbymkV » Mon Apr 26, 2021 6:06 pm
Yeah, if I could go back in time I would tell myself to stop the quest for Dolby Vision greatness and do something else instead. It has been expensive, time-consuming, and ultimately pretty damn frustrating. I enjoy all the nice and like-minded people around here, but I should have just been content with HDR10+Dynamic Tone Mapping and Nvidia Shields.
Post by Woodstock » Mon Apr 26, 2021 6:58 pm
bobbymkV wrote: Mon Apr 26, 2021 6:06 pm Yeah, if I could go back in time I would tell myself to stop the quest for Dolby Vision greatness and do something else instead. It has been expensive, time-consuming, and ultimately pretty damn frustrating. I enjoy all the nice and like-minded people around here, but I should have just been content with HDR10+Dynamic Tone Mapping and Nvidia Shields.
This is an adventure game. You have a goal. You have some tools that might help you achieve the goal. You have to obtain other tools. Wizards and Dragons oppose you. Some times you can glimpse the goal, other times it is obscured in a fog of doubt. Eventually, you discover that the goal isn't a solid object, but a concept that can be nebulous. And yet you persevere...
