Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
john769
Re: Ultimate UHD Drives Flashing Guide Updated 2021
#721 Post by john769 » Mon Apr 19, 2021 10:23 am
hey, an update after month of using LG BP60NB10 :
i thought at first it was the drive and sent it to repair shop and after i got it back sometime it works but most of the time i get a lot of error DEBUG: "CODE 3221225664 at jot[uQ>o.oH&@FAI:29399197" and "HASH ERROR"..
so i order second drive LG WH14NS40 but the same as LG BP60NB10 ???
BUT here the BIG BUT with ANYDVD LG BP60NB10 WORK FLAWLESSLY so far i ripped around 5TB and rip the same disks more than once to check the HASH...
maybe there is problem with my pc hardware something interfere with MAKEMKV even with clean windows install and only makemkv installed i get ERROR :?:
Koyaanisqatsi
#722 Post by Koyaanisqatsi » Thu Apr 22, 2021 8:31 pm
I'm getting blocked on all the links I have tried in the first post of this thread. This is just happening in the last few days. Anyone else getting this, or is it just me? Looks like the hosting provider for makemkv.com is intercepting the requests. The resulting page appears to be in Russian.
#723 Post by Billycar11 » Sat Apr 24, 2021 12:49 am
links have been updated to work if any are broken that i missed let me know
anfield
#724 Post by anfield » Sun Apr 25, 2021 8:42 pm
Hello all
I flashed the HL-DT-ST-BD-RE_BH16NS55 1.02 (printed on the Label )with the Firmware update for BH16NS55 (Ver. 1.05)
The flash goes wrong and now it show BH16NS40_boot.
i wish to reflash it wir the HL-DT-ST-BD-RE_BH16NS55 1.02 Firmware.
i have downloaded the sdf flasher 1.20 and the downgraded enable firmware 2.0 files.
But when i start the flasher and select the drive HL-DT-ST-BD-RE_BH16NS55 1.02 and the firmwareDE_flash_HL-DT-ST_BD-RE_BH16NS55_1.02.bin.
now i choose the Recovery drive.
and now clicking on start.
and Nothing.
the flasher wont work.
Win7 x64 sp1. or win10 pro x64 20h2
i tried the asus flasher but i get an error update failure 5.
any help welcome.
kiam001
Re: Ultimate UHD Drives Guide Updated 2019
#725 Post by kiam001 » Mon Apr 26, 2021 9:03 pm
wag12wag12 wrote: Tue Feb 11, 2020 11:49 am
kiam001 wrote: Thu Aug 08, 2019 6:26 am My CH12NS40 can After Patch read 4k Blu-rays
Hi, I also have a CH12NS40 , where can I find information on how to do this patch to enable 4K read?
You find it here in this Forum, i dont known is long time ago
But i patch to from my frind the CH12NS40 to read 4K disks
Wirhout patch Windows say Disk is not readable
With patch it opens as data CD
0x15e
#726 Post by 0x15e » Fri Apr 30, 2021 3:00 pm
I just wanted to say thanks for putting together such a comprehensive and easy-to-follow guide for which drives to use and how to flash them. I was able to get a BU40N from Amazon and easily use the GUI sdftool to put the 1.03 MK firmware on it (it actually came with 1.01 so no encryption was involved).
Also, even though I got my own drive and did the flashing myself (and it wasn't particularly hard), if I had to do it again, I'd buy one from one of the sellers here. I thought I'd save a few bucks doing it myself but it really was a false economy. Between waiting a week for the drive to get here, having to buy a slim ODD mount kit and adapter cables (that I ended up not even being able to use because the kit was for a 12.7mm drive but the BU40N is 9.5mm), and finally ending up buying an external enclosure anyway, I easily spent what, e.g., Billycar11 is charging. That price looks like a big chunk to spend all at once but when you add up all the nickel-and-dime crap you need to use this drive, it comes out about the same.
Agendum
#727 Post by Agendum » Sat May 01, 2021 5:29 am
Has anybody ever gotten this error from the sdftool?
C:\Program Files (x86)\MakeMKV>sdftool -d E: flash -i D:\flash\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Unknown command
Command produced error code 0x8fffffff
C:\Program Files (x86)\MakeMKV>sdftool64 -d E: flash -i D:\flash\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Unknown command
I have the below drive and am trying to flash it so that I may enable LibreDrive:
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: <snip>
Firmware date: 2120-05-08 10:10
Highest AACS version: 76
I also tried the GUI tool but it crashes, likely due to this unexpected output.
Agendum
#728 Post by Agendum » Sat May 01, 2021 7:45 pm
For anybody who runs into the same problem, I was using the wrong command. The proper command for me was:
makemkvcon64.exe f --all-yes -d E: rawflash enc -i "D:\flash\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin"
#729 Post by MartyMcNuts » Sat May 01, 2021 11:31 pm
Agendum wrote: Sat May 01, 2021 5:29 am Has anybody ever gotten this error from the sdftool?
Unknown command
Unknown command
OS device name: E:
Revision: 1.03
You have encrypted firmware. Add "enc"to your command or check the box in SDFtool Flasher.
Chris Kelly
#730 Post by Chris Kelly » Fri May 07, 2021 2:50 pm
From what I can tell, I don't think the latest firmware for the ASUS BW-16D1HT is encrypted since it was released in March of 2019. I'm just confirming this. Being that LG has still been updating/upgrading their firmware since then and this drive is designed by LG, I'm surprised and puzzled that ASUS hasn't continued to update/upgrade the firmware for this drive.
stepmback
#731 Post by stepmback » Mon May 10, 2021 2:19 pm
I had a disc explode in my drive and now my drive is done. Won't read anything. Never had that happen before but the drive was old and served me well over the last couple of years.
I need a new internal drive. I see there are deals for $60 on the WH14NS40 is that a good replacement drive for ripping UHD movies. I don't mind paying extra for something solid but I do want an internal 5.25 drive.
pereirafch
#732 Post by pereirafch » Sat May 15, 2021 6:45 am
Hello! I just got an ASUS BW-16D1HT that has the 3.10 fw and I used the 3.10MK fw to flash it. I mistakenly flashed it using the "enc" command line as if it was encrypted. I then realized it wasn't encrypted and I flashed it again using the "rawflash" command line. After doing this second flash, the drive is now able to read and rip UHD discs. Even though I can rip the UHD discs now, I'm just looking to confirm that everything is fine and I didn't damage the drive. I would appreciate anyone's comment, this was the first time I flashed a drive.
Thanks!!
#733 Post by Billycar11 » Sat May 15, 2021 7:15 pm
pereirafch wrote: Sat May 15, 2021 6:45 am Hello! I just got an ASUS BW-16D1HT that has the 3.10 fw and I used the 3.10MK fw to flash it. I mistakenly flashed it using the "enc" command line as if it was encrypted. I then realized it wasn't encrypted and I flashed it again using the "rawflash" command line. After doing this second flash, the drive is now able to read and rip UHD discs. Even though I can rip the UHD discs now, I'm just looking to confirm that everything is fine and I didn't damage the drive. I would appreciate anyone's comment, this was the first time I flashed a drive.
Thanks!!
Your fine
ProNub
#734 Post by ProNub » Mon May 17, 2021 4:24 am
Hey Billy and all,
I did the original hex hack Mike posted two years ago on my WH16NS60 and got it to 1.00. I see you recommend
WH16NS60 on any Firmware directly to > WH16NS60 1.02MK
Are there any advantages to 1.02MK over 1.00DE?
My guesses according to these MK properties from Mike:
Possible firmware improvements
WH16NS60 1.00DE should have all the vendor commands but maybe not
Inapplicable - WH16NS60 is allowed to read UHD discs
Probably but irrelevant - 1.00DE may still have the checks preventing firmware downgrades but it's the base firmware anyway
Inapplicable - "encrypted" downgrade check
The MK firmware has the following properties:
Made from the latest available official firmware.
Re-enabled vendor commands to update microcode in memory.
Re-enabled ability to read UHD discs (if drive was capable, and disabled in firmware).
Removed firmware downgrade check (if present in firmware).
Removed firmware "encrypted" downgrade check (if present in firmware).
No other changes.
#735 Post by Billycar11 » Mon May 17, 2021 4:47 am
ProNub wrote: Mon May 17, 2021 4:24 am Hey Billy and all,
No other changes.
nah just stay on the firmware you are on
