Post by RESET_9999 » Mon Apr 12, 2021 1:31 am
mulucy wrote:
Mon Apr 12, 2021 12:19 am
Would you recommend Chromecast with Google TV based on the test results you are getting? I am not into any serious lossless audio setup, it's all lossy since I live in the apartment ( I don't even have Atmos speakers, will get them once I move into my house later ). My main concern is the support for DV FEL and other HDR formats with my Vizio PX Quantum and TCL 6 Series. I mainly watch movies from UHD disk backups .
Just to add more to my comment, I am very happy with my Fire TV Sticks 4K. They are rock solid, do support MEL DV and have auto frame rate on top on most apps.
Thank you again!
My only concern is the fact that it output DV in player-led mode by default (at least with my C8) when it's fully capable of sending tv-led DV.
I don't really know about its playback stability yet but overall, I think it is a better device than the firestick tv because of FEL support. (better DV + no bothering with the conversion from fel to p8)
Also, I had a firestick a while ago and it supported the appleTV app in 60hz only while the Chromecast may not be able to switch frame rate automatically but if you leave it in 23.976, you'll be fine for most of the movies.
RikkiKu
Post by RikkiKu » Mon Apr 12, 2021 6:05 am
RESET_9999 wrote:
Tue Mar 30, 2021 10:32 pm
galarond wrote:
Tue Mar 30, 2021 10:20 pm
Theres any way to convert a dv mkv dual layer mixed into 1 video file, to a normal dual layer mp4?
Extract the hevc stream from mkv with mkvextract (or tsmuxer, ffmpeg, mkvcleaver) and then demux the hevc stream with yusesoap tool (DEMUX.bat) which will split the layers and then build a new dual-layer dual-track mp4 with the mp4muxer
viewtopic.php?f=12&t=18602&start=2970#p96282
I did the same but it doesn't work
Post by RESET_9999 » Mon Apr 12, 2021 4:20 pm
i don't know about your playback device but it does work, I did it many times.
kazuma
Post by kazuma » Fri Apr 16, 2021 6:21 pm
where can i download a small sample file of mkv dolby vision?
bobbymkV
Post by bobbymkV » Fri Apr 16, 2021 8:09 pm
https://www.makemkv.com/download/dvtest/
kazuma
Post by kazuma » Sat Apr 17, 2021 11:37 am
thnx! none of the files worked als DV on my chinoppo m9201 and LG C9. are these dual-layer dv's? where can i find the post to make DV-mkv?
userr
Post by userr » Sat Apr 17, 2021 3:53 pm
RESET_9999 wrote:
Fri Apr 09, 2021 1:17 am
Just got a Chromecast, and I confirm that it's a FEL DV capable device. The ending credits of Power rangers is bright white... FEL noise visible on test file as confirmed before. great player for my bedroom TV :)
player-led and tv-led seem to be behaving strangely ... on my C8 OLED I'm only getting LLDV(player-led) but on my cheap Vizio TV which doesn't support LLDV I get TV-led DV. HDR10 and SDR are color accurate.
*tested iTunes, Movies Anywhere, and PLEX
also, no red push in the Dr. Sleep p7 rip. The Shield is really the only device that has color issues and yet, the nvidia staff still say that they don't see any difference :lol: ...
very interesting, still satisfied with it?
edit: i havent been paying attention for a good while. Last time i was reading here, we really didnt know if FEL was even displayed correctly on 2019 shield, any news on that?
Im asking you because i know you are know much about this DV subject :)
norrellmeister
Post by norrellmeister » Sat Apr 17, 2021 11:16 pm
Spent some time with the Chromecast Google TV today with Plex. I confirmed that FEL is playing, as expected. Some mkv remuxes don’t seem to DV at all without manually switching audio tracks, because they start to direct stream instead of direct play due to audio codec limitations, and on this device that breaks DV. When DV does work, audio is often showing up as multichannel PCM on the receiver, as expected based on other posts here. Image quality looks really good, probably better than the Shield. I did see one situation where audio and video got out of sync, and one situation where the FEL layer was playing just slightly out of sync. This was visible as ghosting in Power Rangers white credits. Seeking in the video fixed that up quickly.
One more thing: stability is overall better than Ugoos, but I am seeing issues where if I switch sway from Plex, the video goes to HDR mode instead of DV. Restarting the video fixes it. Not perfect, but likely better than the Shield for my purposes, for P7 files.
The device was set to 24p manually, since it has no auto frame rate switching.
userr
Post by userr » Sun Apr 18, 2021 2:33 pm
doesnt the plex app itself have framerate switching tho?
psychoboust
Post by psychoboust » Mon Apr 19, 2021 10:34 am
Do you think some new 2021 TV with the last Android TV version will be able to run some MP4 or MKV DV profile directly from the TV without any external box ?
I was looking for a new TV and wonder if it will be possible to get that without my Shield Pro...
chros
Post by chros » Mon Apr 19, 2021 8:11 pm
RESET_9999 wrote:
Fri Apr 09, 2021 5:30 pm
chros wrote:
Fri Apr 09, 2021 3:32 pm
I've added the B8 DoVi graphs into the post above.
so since my TV use maxcll (or MDL when no maxcll) and because maxcll is not very reliable(often incorrect), is it better to use madvr ''output in hdr'' with peak set to 700nits? what do you use ?
Come over the doom9 LG Oled with madvr thread we can talk about it more there.
DaMacFunkin
Post by DaMacFunkin » Tue Apr 20, 2021 4:43 am
When I had the CCwGTV no app would switch the refresh rate, not even Plex, it needed to be done in settings which lead me to believe frame rate switching isn’t supported on the device, I even tried the refresh rate app from the shield but it wouldn’t run.
mulucy
Post by mulucy » Sat Apr 24, 2021 6:16 pm
What's happening with the main website?
Epedemic
Post by Epedemic » Sat Apr 24, 2021 9:35 pm
Good question, seems like missing payment on hosting (or the hosting providers hosting), but that's just speculation.
Epedemic
Post by Epedemic » Sat Apr 24, 2021 9:41 pm
So, i've about had it with the shield... the ugoos seems dead on arrival.... the oppo 203 is too damn expensive.... the chinoppo seems dodgy at best (and is also too expensive..... and the cc with google tv dosen't do lossless... That pretty much leaves me with the option of the X700... Correct?
Also, if i go down this path: is it possible to convert my .mkv library (with DV) back to bdmv folder structure, or do i need to rerip (or... ew... play discs)?
