"No drive tool logic.." when flashing BU40N
medikoo
Post by medikoo » Fri Apr 16, 2021 2:12 pm
I just got the BU40N in Archgon enclosure, which came with 1.01 firmware. I've attempted to flash it with 1.03 MKV firmware, still I get the following error
c:\Program Files (x86)\MakeMKV>makemkvcon64.exe f -v --all-yes -d D: rawflash enc -i C:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Loaded SDF.bin version 0x7e
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Is there a way to recover and flash it? (note: I've already flashed 3 drives, twice BU40N, and never approached such issue)
Re: "No drive tool logic.." when flashing BU40N
Post by Billycar11 » Fri Apr 16, 2021 8:45 pm
No enc
medikoo
Post by medikoo » Sat Apr 17, 2021 8:14 am
Billycar11 wrote: Fri Apr 16, 2021 8:45 pmNo enc
Thanks @Billycar11 for help. Still that doesn't bring any difference
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f -v --all-yes -d D: rawflash -i C:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Post by Billycar11 » Sat Apr 17, 2021 8:48 am
medikoo wrote: Sat Apr 17, 2021 8:14 am
makemkvcon64.exe f --all-yes -d D: rawflash -i C:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
use that^
where are you getting your commands from? my guide has no -v
medikoo
Post by medikoo » Sat Apr 17, 2021 3:27 pm
Billycar11 wrote: Sat Apr 17, 2021 8:48 am makemkvcon64.exe f --all-yes -d D: rawflash -i C:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
use that^
I found hint about -v at some other post in a forum, that it produces more verbose output. Without -v is effect is same, just output is less verbose):
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash -i C:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Post by Billycar11 » Sat Apr 17, 2021 6:46 pm
medikoo wrote: Sat Apr 17, 2021 3:27 pm
use that^
Open a disc in makemkv and try again
Post by Billycar11 » Sun Apr 18, 2021 4:28 am
i think i know whats wrong what adapter are you using to flash this drive?
medikoo
Post by medikoo » Mon Apr 19, 2021 11:59 am
Unfortunately that doesn't help
Screenshot 2021-04-19 at 13.49.58.png (92.19 KiB) Viewed 32950 times
What do you mean by "adapter"? It's Archgon external -> https://www.amazon.de/dp/B07B2RMXKW/ref ... 01_TE_item simply connected via USB 3.0 cable.
What's interesting it that it's fixed drive returned to me after servicing. When I bought it new, I had not issues with flashing it, still after some time got broken (started to be very noisy and produced many errors while ripping), I've send it back for guarantee service, and what I received back is a unit, again with a original Firmware, which now I'm not able to flash over.
Post by Billycar11 » Mon Apr 19, 2021 12:08 pm
I'm thinking the new case may not be passing through flashing commands I think all your stuff is correct don't know what else could be wrong
Try with the asus flasher see what happens
medikoo
Post by medikoo » Mon Apr 19, 2021 12:14 pm
I think it gets same error:
Screenshot 2021-04-19 at 14.12.15.png (35.53 KiB) Viewed 32947 times
I'll see later, maybe I can remove it from case, and check with the other. Still that's weird, as in very same case I was able to flash it previously (when it was new, before servicing)
Post by Billycar11 » Mon Apr 19, 2021 12:17 pm
Yeah I'm pretty sure your case is not passing flashing commands
medikoo
Post by medikoo » Wed Apr 28, 2021 8:30 pm
Billycar11 wrote: Mon Apr 19, 2021 12:17 pm Yeah I'm pretty sure your case is not passing flashing commands
You were right, I've just put this drive to different case and was able to flash without issues.
It's interesting as in same enclosure without issues I flashed this drive when it was new, it's version I got back after servicing that didn't allow flashing.
Post by MartyMcNuts » Sat Apr 16, 2022 10:12 pm
medikoo wrote: Wed Apr 28, 2021 8:30 pm
How did you remove the drive from the Archgon enclosure?
Post by Billycar11 » Sat Apr 16, 2022 11:17 pm
MartyMcNuts wrote: Sat Apr 16, 2022 10:12 pm How did you remove the drive from the Archgon enclosure?
There are screws under the front or rear rubber feet can't remember off the top of my head I want to say rear. Then from there it's self explanatory
