File Compression
bcrozierw
File Compression
Post by bcrozierw »
I'm brand new here - so apologize if the answer here is obvious ...
I'm using MakeMKV to rip my dvd and bluray library to a NAS (100 titles so far) but I'm running out of space.
My son tells me a typical 1080p move should take up less than 4 gb, but mine are averaging 25+.
How do I compress these files? ... can't find anything in Preferences
Re: File Compression
MakeMKV won't do video compression. But, tools like handbrake can.
Compressing a 1080p video to "less than 4gb" depends on how much quality you're willing to give up and how compressible the source is. Something like anime will usually compress to 10-15% of original size, but a fast-moving live-action (or special effects-laden) movie might only compress to 50% size.
Recent examples from my use, "The Russians Are Coming" was a 22GB movie on disk, and compressed to 11GB. "It's a Mad, Mad, Mad, Mad World" was 39GB on disk, 11GB after compressing, both with handbrake presets that favored high quality.
bcrozierw
Post by bcrozierw »
Thank you very much.
Should I keep using Make MKV or is there a ripper that will compress its output?
I recently did the blu-ray Bumblebee (2018). It was a 28GB rip. I turned it into a 7.5GB h.264 file (using Handbrake & Intel QuickSync hardware encoding) and a 3.9GB 10-bit h.265 file (using ffmpeg & x265 software encoder). The h.264 took about 18 minutes because of the hardware encoding. The h.265 encode took about 3 hours, 45 minutes.
Also, big hard drives are relatively inexpensive. Putting big hard drives in your NAS to be able to skip the transcoding of your rips is a good example of trading money for time.
bcrozierw
Post by bcrozierw »
Thank you both ... I will try handbrake.
My NAS is a Synology DS420+ with 4 2TB drives.
I might have made a mistake choosing 2-drive fault tolerance when I was expecting my 600 titles to require less than 4 TB ...
Imagine my surprise when Synology tells me I'm at 80% capacity with 100 rips.
I guess I'll go on the Synology Forum to see if I can recover some of that extra space.
lolotux
Post by lolotux »
Hi
I use HandBrakeCLI to compress generated file by MakeMKV.
As this example : HandBrakeCLI -i "title_t02.mkv" --preset "Fast 1080p30" -t 1 -a 2 -s 3 -w 1920 -l 1080 --align-av -o "Harry Potter et les Reliques de la Mort, partie 1.2010.FRENCH.1080p.H264.mp4"
Then with ma computer : One hour with makemkv and about 35mins with handbrake.
NB : Yep I'm french... ;)
