#4936 Post by RESET_9999 » Sat Apr 10, 2021 9:54 pm
quietvoid wrote: Thu Mar 11, 2021 1:22 am Right, but I wouldn't personally consider bad shadows a good experience even if it's brighter :wink:
At least that's what I've noticed. HDR is supposed to have good lower range as well, which isn't the case with Dolby Vision on these TV sets.
I've edited the test pattern in the post a little late, here it is again:
It's FEL so you can compare HDR10 and Dolby Vision.
Hi there,
ok sorry for the late reply, it took me a while to check this pattern but indeed, DV black level is wrong compared to HDR10. It is very obvious in my pitch-black room. I decided to check it out after noticing the ugly raised black on ''All man kind'' on my Shield. Then I went back comparing some movie that I remembered having terrible black level when I watched them in DV (I assumed it was how they graded it) and I actually always compared brighter scenes which are easier to capture with my camera.
so on my x700, I checked Atomic Blonde Dual-layer rip. if you pause at 34sec(frame 848) the image is dark grey/black in both HDR10 and DV but you can't see the black bars at all in DV, they are elevated while in HDR10 you can clearly see the darker black bars. the DV version actually looks like a full screen 16:9 movie for a couple of frames lol .
Just to be sure the problem was not my x700, I checked All mankind P5 DV on the Shield which as I said, I noticed has elevated black too. again right in the first few seconds of episode 8, perfect black level in HDR10 but ugly raised black in DV.
Are sure this is only a problem with these TV sets because not only I'm seeing the same thing on my Vizio tv but I can also capture it with my x700 dv to HDR conversion(no c8 in the chain) which I thought was faulty because of the black level but I now think it turns out that it actually captures how the black level are messed up in DV. to me all of this sound like a major issue with DV algorithm.
dual-layer FEL black level pattern comparison: https://screenshotcomparison.com/comparison/13253
* represent exactly what I'm seeing in a pitch-black room. of course, check out this comparison with all the lights off.
Atomic blonde 34sec frame 848: https://screenshotcomparison.com/comparison/12921
*again represent exactly what I'm seeing in real life. also, the difference is only very obvious in a completely dark room.
all of this is disappointing to me, a lot, I almost wish you never told me that lol ... its either a punchier/brighter image in DV with horrible black level or a darker HDR10 image with better contrast and inky black level.
quietvoid
#4937 Post by quietvoid » Sat Apr 10, 2021 10:24 pm
RESET_9999 wrote: Sat Apr 10, 2021 9:54 pm Hi there,
dual-layer FEL black level pattern comparison: https://screenshotcomparison.com/comparison/12918
I don't know about other TVs but with my C8, blacks in Dolby Vision with an HDMI input are more elevated than the internal apps.
Some people say only the Apple TV suffers from this but it also happens with my Firestick 4K. So I end up using brightness 49 everywhere, but this significantly crushes near-black.
I've personally reported the issue to LG but according to sspears IIRC the issue needs to be fixed by Dolby.
I was just told they would look at it (sent examples) and that the issue would be fixed in a firmware update. That was a month ago.
It's a sad situation..
#4938 Post by RESET_9999 » Sat Apr 10, 2021 10:30 pm
quietvoid wrote: Sat Apr 10, 2021 10:24 pm
yep, I can see the issue on ALL my devices/TV and it's really only noticeable in a dark room with an oled so I get why some people won't notice it but it sure looks like a Dolby issue.
Very sad. I guess that explains why everytime I'm impressed by the black level in a movie, it's always with HDR10 movies.
captainbrent
#4939 Post by captainbrent » Sat Apr 10, 2021 11:15 pm
RESET_9999 wrote: Sat Apr 10, 2021 8:03 pmgreat, just ordered one. thank's
You are very welcome...let us know if it works alright!
XTrojan
#4940 Post by XTrojan » Sun Apr 11, 2021 7:31 am
Can someone install Kodi on the latest chromecast and see if it supports FEL playback with lossless audio and no bugs? Been thinking of buying it but hesitating due to how the ugoos turned out
morbius
#4941 Post by morbius » Sun Apr 11, 2021 8:56 am
[/quote]
[/quote]
don't know if this is relevant, but with my Panny HZ980, when the DV mode is TV-led ("mode 1" in the Panny menu), black levels are elevated far too much across multiple sources (Shield/Plex playing mkv's, ATV streaming apps, Sony X700). My go-to test scene is the saloon bar in Back to the Future 3 about 30mins into the film. The bar looks flood-lit with TV-led DV. If I switch to player-led DV, the black levels are much more sensible, and the picture looks right, more aligned to HDR10 on the ATV and HDR10+ on the Vero 4K. No idea if this is a Panny issue or a Dolby issue.
lexyz
#4942 Post by lexyz » Sun Apr 11, 2021 11:51 am
I'm quite sure it's Dolby 8)
For now there is so many issues with Dolby Vision on various devices.
Can't wait for a new S&M UHD HDR Benchmark disk with DV patterns. :roll:
So many wonderful discoveries await ahead :lol:
#4943 Post by RESET_9999 » Sun Apr 11, 2021 5:57 pm
XTrojan wrote: Sun Apr 11, 2021 7:31 am Can someone install Kodi on the latest chromecast and see if it supports FEL playback with lossless audio and no bugs? Been thinking of buying it but hesitating due to how the ugoos turned out
DV MKV on kodi triggers DV for a second and stop. HD audio passthrough is not supported.
-for DTS-HD DTS-X, it will bitstream the DTS lossy core
-for TrueHD, it will send audio as LPCM stereo
- lossy DD+ atmos and DD bitstream works
- same behavior on PLEX but it will play DV MKV as long as the selected audio is not TrueHD.
- DD+ atmos works on iTunes but not on Movies Anywhere.
I'm not able to get tv-led DV on my OLED C8, tried many times, no luck. HDR10/SDR/DV are all sent in 422 12bits and the colors are accurate on the C8. So it looks like the chromecast default DV mode is LLDV and only display that doesn't support LLDV get TV-led DV.
On my Vizio TV(doesn't support LLDV), I get tv-led DV but then HDR10/SDR are stuck in 444 8bit resulting in incorrect HDR10 colors just like the ugoos device. SDR 8bit 444 is color accurate though.
In the display settings, if I select 24hz SMTP, then HDR10/SDR are 444 12bit and colors are accurate but I lose DV on everything (plex iTunes Ma vudu fandango etc). Also, every time you switch from 24hz to 24hz SMTP, you have to reboot the device.
Itunes is converting DV to HDR10 on the fly like the appleTV used to do. It's sending random metadata. Movies anywhere send pure HDR10 stream. Didn't test the other apps.
Vizio 24hz mode HDR10 (DV works but incorrect 8bit in HDR10)
24hz SMTP mode HDR10: (same for vizio and C8) (DV doesn't work but 12bits in HDR10)
OLED C8 (no tv-led support):
Vizio DV (tv-led support):
iTunes DV in HDR10 (wrong metadata)
Movies anywhere DV in HDR10 (proper metadata)
mulucy
#4944 Post by mulucy » Mon Apr 12, 2021 12:19 am
RESET_9999 wrote: Sun Apr 11, 2021 5:57 pm
Would you recommend Chromecast with Google TV based on the test results you are getting? I am not into any serious lossless audio setup, it's all lossy since I live in the apartment ( I don't even have Atmos speakers, will get them once I move into my house later ). My main concern is the support for DV FEL and other HDR formats with my Vizio PX Quantum and TCL 6 Series. I mainly watch movies from UHD disk backups .
Just to add more to my comment, I am very happy with my Fire TV Sticks 4K. They are rock solid, do support MEL DV and have auto frame rate on top on most apps.
Thank you again!
#4945 Post by RESET_9999 » Mon Apr 12, 2021 1:31 am
mulucy wrote: Mon Apr 12, 2021 12:19 am
Thank you again!
My only concern is the fact that it output DV in player-led mode by default (at least with my C8) when it's fully capable of sending tv-led DV.
I don't really know about its playback stability yet but overall, I think it is a better device than the firestick tv because of FEL support. (better DV + no bothering with the conversion from fel to p8)
Also, I had a firestick a while ago and it supported the appleTV app in 60hz only while the Chromecast may not be able to switch frame rate automatically but if you leave it in 23.976, you'll be fine for most of the movies.
RikkiKu
#4946 Post by RikkiKu » Mon Apr 12, 2021 6:05 am
RESET_9999 wrote: Tue Mar 30, 2021 10:32 pm
galarond wrote: Tue Mar 30, 2021 10:20 pm Theres any way to convert a dv mkv dual layer mixed into 1 video file, to a normal dual layer mp4?
Extract the hevc stream from mkv with mkvextract (or tsmuxer, ffmpeg, mkvcleaver) and then demux the hevc stream with yusesoap tool (DEMUX.bat) which will split the layers and then build a new dual-layer dual-track mp4 with the mp4muxer
viewtopic.php?f=12&t=18602&start=2970#p96282
I did the same but it doesn't work
#4947 Post by RESET_9999 » Mon Apr 12, 2021 4:20 pm
RikkiKu wrote: Mon Apr 12, 2021 6:05 am
i don't know about your playback device but it does work, I did it many times.
kazuma
#4948 Post by kazuma » Fri Apr 16, 2021 6:21 pm
where can i download a small sample file of mkv dolby vision?
bobbymkV
#4949 Post by bobbymkV » Fri Apr 16, 2021 8:09 pm
kazuma wrote: Fri Apr 16, 2021 6:21 pm where can i download a small sample file of mkv dolby vision?
https://www.makemkv.com/download/dvtest/
kazuma
#4950 Post by kazuma » Sat Apr 17, 2021 11:37 am
bobbymkV wrote: Fri Apr 16, 2021 8:09 pm
thnx! none of the files worked als DV on my chinoppo m9201 and LG C9. are these dual-layer dv's? where can i find the post to make DV-mkv?
