Unable to rip Blu-ray's with LG BH10LS30
cbrad
#1 Post by cbrad » Tue Jan 25, 2011 10:37 pm
Hi there
I can rip DVD's fine, but have tried 3 blu-ray's and they all failed to open with very similar errors. This is using an LG BH10LS30 in an external enclosure, connected via USB to a MacBook Pro.
Debug log.
Debug log started at Tue Jan 25 21:05:34 2011 , written by MakeMKV v1.6.3 darwin(x86-release)
001003:0020 DEBUG: Code 6094848 at 'u<[]5WgK1,d|&;Fk>+An_l:213130007
001005:0000 MakeMKV v1.6.3 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/brad/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW  GS23N SB03" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE  BH10LS30 1.00" opened in OS access mode.
001003:0020 DEBUG: Code 0 at wx2,&iBo%7U59,XhVM:p|jS?sQw;:213132100
001003:0020 DEBUG: Code 0 at @Eg%.+eZL4vNS|}<o:213131042
001003:0020 DEBUG: Code 0 at wx2,&iBo%7U59,XhVM:p|jS?sQw;:213131571
001003:0020 DEBUG: Code 0 at wx2,&iBo%7U59,XhVM:p|jS?sQw;:121264050
001003:0020 DEBUG: Code 1073741830 at &A(f>JE\[s!ChSo7zb:29395839
001003:0020 DEBUG: Code 1073741830 at &A(f>JE\[s!ChSo7zb:121261727
002003:0000 Error 'Posix error - Device not configured' occurred while reading 'BD-RE HL-DT-ST BD-RE  BH10LS30 1.00' at offset '524288'
002003:0000 Error 'Posix error - Device not configured' occurred while reading 'BD-RE HL-DT-ST BD-RE  BH10LS30 1.00' at offset '1048576'
001003:0020 DEBUG: Code 1073741830 at &A(f>JE\[s!ChSo7zb:121264579
002003:0000 Error 'Posix error - Device not configured' occurred while reading 'BD-RE HL-DT-ST BD-RE  BH10LS30 1.00' at offset '32768'
001003:0020 DEBUG: Code 0 at 9>@]v,QTQ1I,qGp9vx7:29393447
Application exited at Tue Jan 25 22:31:05 2011
Any help would be greatly appreciated.
Re: Unable to rip Blu-ray's with LG BH10LS30
#2 Post by mike admin » Wed Jan 26, 2011 8:35 am
A generic drive SCSI error. It might[/b] the problem with enclosure. The next program version is very likely to correct this problem.
cbrad
#3 Post by cbrad » Wed Jan 26, 2011 10:23 am
Thanks for the quick response. Is there a planned release timeframe for the next version? Is there a stable nightly build that I could try?
skittle
#4 Post by skittle » Wed Jan 26, 2011 6:01 pm
cbrad wrote:Is there a planned release timeframe for the next version?
Mike usually does not say... but probably in the near future *weeks*
cbrad wrote:Is there a stable nightly build that I could try?
This is an oxymoron, and no. The beta builds that are released to us are as essentially the only 'stable nightly'.
priitv8
#5 Post by priitv8 » Wed Jan 26, 2011 7:46 pm
I have a similar issue, although both my drive and particular error message are different. I had an obsolete Sony BDP-S300 BD player. I thought I can utilise it's internal ATAPI drive, Sony BPD-100 as an external BD drive for ripping. Can it be that I'v been too naive? That despite similar exterior, this drive is not suitable as external BD drive? I get the unable to get VID error as can be seen in attached logs. I've tried all OS and direct methods combined with all workaround algorithms. All to no avail.
I've also tested 2 different USB to ATA bridges, results don't depend on the interface.
Cypress AT2LP RC42:
  Capacity:	8,88 GB (8 877 899 776 bytes)
  Removable Media:	Yes
  Detachable Drive:	Yes
  BSD Name:	disk5
  Product ID:	0x6830
  Vendor ID:	0x04b4  (Cypress Semiconductor)
  Version:	 4.20
  Serial Number:	5000000000016888
  Speed:	Up to 480 Mb/sec
  Location ID:	0x26200000
  Current Available (mA):	500
  Current Required (mA):	2
  Media Name:	SONY_BRAVIA_3D_DEMO
  Partition Map Type:	Unknown
  S.M.A.R.T. status:	Not Supported
USB to ATA/ATAPI Bridge:
  BSD Name:	disk1
  Product ID:	0x2338
  Vendor ID:	0x152d  (JMicron Technology Corp.)
  Version:	 1.00
  Serial Number:	000000000000
  Manufacturer:	JMicron
The BDP-S300 firmware was updated to latest version before opening it up. That ought include the drive firmware update.
I've also searched the net for data about BPD-100 drive, but neither technical details nor it's usage patterns outside the BDP-S300 machine could be found.
Can this drive be used with makeMKV or shall I look for a specially designed computer drive?
#6 Post by mike admin » Fri Jan 28, 2011 10:44 am
priitv8 wrote:I had an obsolete Sony BDP-S300 BD player. I thought I can utilise it's internal ATAPI drive, Sony BPD-100 as an external BD drive for ripping. Can it be that I'v been too naive?
MakeMKV doesn't support such drives. It might in future but no promises.
priitv8
#7 Post by priitv8 » Fri Jan 28, 2011 11:38 am
mike admin wrote:MakeMKV doesn't support such drives. It might in future but no promises.
OK, I see. In what ways is this drive different from a "normal" ATAPI/SATA BD-drive for computer use?
leenuss
#8 Post by leenuss » Sat Jan 29, 2011 7:19 pm
I have ripped 6 Blurays so far using my LG BH10LS30 on OS X Snow Leopard.
No problems. MakeMKV is the only software able to rip all bluray discs on my Mac, other ripping softwares will fail on some discs.
cbrad
#9 Post by cbrad » Sat Feb 05, 2011 11:10 am
leenuss wrote:I have ripped 6 Blurays so far using my LG BH10LS30 on OS X Snow Leopard.
Have you installed the drive internally or are you using it externally (if so how)?
cbrad
#10 Post by cbrad » Sat Feb 05, 2011 11:15 am
mike admin wrote:A generic drive SCSI error. It might[/b] the problem with enclosure. The next program version is very likely to correct this problem.
I have just installed v1.6.4 and unfortunately I still can't rip Blu-rays.
Debug log started at Sat Feb  5 11:02:52 2011 , written by MakeMKV v1.6.4 darwin(x86-release)
001005:0000 MakeMKV v1.6.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/cbrad/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL PIONEER DVD-RW  DVR-K06 Q609" opened in DASPI mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE  BH10LS30 1.00" opened in DASPI mode.
001003:0020 DEBUG: Code 0 at Zx0Pz>DlaL[pA+Mp}i(dyM^\Q:213131318
001003:0020 DEBUG: Code 2281701379 at EJ6~!AJ/a/wtMuf7:29397357
<snip> lots of the same lines</snip>
#11 Post by mike admin » Tue Feb 08, 2011 9:38 am
cbrad wrote:I have just installed v1.6.4 and unfortunately I still can't rip Blu-rays.
Thanks for posting the log, the error is new. Please try the following: with MakeMKV not running, insert a BD disc into drive. Only after disc shows up on desktop, launch MakeMKV and see if anything changes.
cbrad
#12 Post by cbrad » Tue Feb 08, 2011 11:11 am
mike admin wrote:Thanks for posting the log, the error is new. Please try the following: with MakeMKV not running, insert a BD disc into drive. Only after disc shows up on desktop, launch MakeMKV and see if anything changes.
The first time I did that, the log was slightly different (line 5 is new).
Debug log started at Tue Feb  8 10:52:26 2011 , written by MakeMKV v1.6.4 darwin(x86-release)
001003:0020 DEBUG: Code 5 at J'D6g}}HF]cJ7/:29395563
When I close MakeMKV the disc has disappeared from the finder and I can't eject it. I need to turn the external enclosure off and on again to eject.
londoner
#13 Post by londoner » Tue Feb 08, 2011 3:32 pm
I am hitting almost exactly the same issue with an LG CH10LS20 (LS20) the drive is in an external USB enclosure.
Debug log started at Tue Feb  8 15:23:44 2011 , written by MakeMKV v1.6.4 darwin(x86-release)
001003:0020 DEBUG: Code 7086080 at *4+t'V-\-1{N%;ZM7&f`1"o:213130007
001004:0000 Debug logging enabled, log will be saved as /Users/jamie/MakeMKV_log.txt
002014:0000 Optical drive "BD-ROM HL-DT-ST BDDVDRW CH10LS20 1.00" opened in DASPI mode.
--- above line repeated over and over ---
cbrad
#14 Post by cbrad » Sun Feb 20, 2011 10:57 am
No change with 1.6.5, still unable to rip blu-rays.
#15 Post by mike admin » Mon Feb 21, 2011 9:10 am
The first 3 messages, you can't get them in 1.6.5 - the bug was fixed. Is it correct? For the rest, please update DASPI to 1.2 and see if it changes anything.
