best way to get small high quality rips?
Re: best way to get small high quality rips?
If you don't want to go down the rabbit hole of transcoding, in the grand scheme of things, DVD rips are relatively small. A 2 hour movie on DVD is usually 5 or 6 GB. A little 2.5" USB powered external hard drive can hold quite a lot of stuff. A 5TB model costs about $100. That would hold 700 - 800 DVD rips. Blu-rays are bigger at 30 - 35GB, but a 5TB drive can hold quite a few of those too. You can always transcode your rips into something smaller later.
I keep all of my rips. I transcode almost all of them into something smaller, mostly because the smaller files makes it easy to put a bunch on a phone, tablet, or laptop for access while I'm traveling. Many of the rips I've transcoded more than once. The slowest and most tedious part of having a digital movie collection is getting the bits off the plastic disc. In an ideal world, it is something you'd only do once.
