splurben
#1
Post
by splurben » Thu Feb 03, 2011 5:27 am
I just installed MakeMKV linux ? (beta) on Gentoo and succeeded with my first Blu-Ray disk.
Gentoo System: Linux-2.6.37-gentoo-x86_64-Intel-R-_Core-TM-_i7_CPU_930_@_2.80GHz-with-gentoo-2.0.1
Requires root / sudo access.
I'm not positive that aacskeys are needed, but I had them installed beforehand and everything's working.
Download ? source and binaries from
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
Save to a folder in your home directory (I created a new directory: ~/makemkv-build)
Make sure the prerequisites are present, I didn't have to add anything as Gentoo is pre-built for making with gcc. (If you were gonna need anything it would probably be
qt4).
Normal linux instructions on download page worked perfectly.
This is good stuff. Thank you MakeMKV!
[/size]
skittle
#2
Post
by skittle » Fri Feb 04, 2011 4:24 pm
Hi, makemkv does not need root access (unless you just meant to install). You are either not part of some group, or you do not have access to some temp folder.
PS: AACS keys are not required by makemkv.
#3
Post
by mike admin » Sat Feb 05, 2011 7:09 am
skittle wrote:Hi, makemkv does not need root access (unless you just meant to install). You are either not part of some group, or you do not have access to some temp folder.
You might need to be a member of "cdrom" group.
splurben
#4
Post
by splurben » Mon Feb 21, 2011 4:13 am
Update to 1.6.5 went smoothly.
skittle
#5
Post
by skittle » Mon Feb 21, 2011 5:36 pm
Hi splurbem can you confirm which group are/were not part of (f any)?
Jugin
#6
Post
by Jugin » Tue Oct 18, 2011 11:51 am
Thanks for the links)) have downloaded successfully and now enjoy using)))
Marla
#7
Post
by Marla » Sat Nov 26, 2011 12:16 am
Thanks a lot, installing now....
Marla
#8
Post
by Marla » Fri Dec 02, 2011 9:11 pm
splurben wrote:I just installed MakeMKV linux ? (beta) on Gentoo and succeeded with my first Blu-Ray disk.
qt4).
[/size]
Thank you very much for the information. I am looking forward to ripping my blue rays to .mkv files to store and watch on my ps3. My only concern here has to do with the audio. Will the .mkv's audio output still be full surround sound, or are there limitations here? I would really hate to lose that, I really love the separation of audio between the
center speaker, left, right, and back speakers. I really hope that this isn't an issue with the software, or I might have to rethink my approach here.
