I've been using MakeMKV for sometime without issue, but lately I've had great difficulty ripping BBC DVDs. The disc starts to open normally, titles are added, but then it just stops without finishing. I've tried adding titles manually, but the same thing happens, the title is "added", but the disk never finishes opening. Thoughts?
MakeMKV v1.16.3 win(x64-release) started
Open DVD manually : "3"
Cells 9-end were skipped due to cell commands (structure protection?)
Title #3 was added (7 cell(s), 0:59:54)
BBC DVDs won't finish opening sequence
Re: BBC DVDs won't finish opening sequence
Do you have the same problem when using the disc with a normal playback program?
