dvidebaek
#4921 Post by dvidebaek » Fri Apr 09, 2021 4:59 am
RESET_9999 wrote: Fri Apr 09, 2021 1:17 am Just got a Chromecast, and I confirm that it's a FEL DV capable device. The ending credits of Power rangers is bright white... FEL noise visible on test file as confirmed before. great player for my bedroom TV :)
player-led and tv-led seem to be behaving strangely ... on my C8 OLED I'm only getting LLDV(player-led) but on my cheap Vizio TV which doesn't support LLDV I get TV-led DV. HDR10 and SDR are color accurate.
*tested iTunes, Movies Anywhere, and PLEX
also, no red push in the Dr. Sleep p7 rip. The Shield is really the only device that has color issues and yet, the nvidia staff still say that they don't see any difference :lol: ...
Is that the new one with Google TV?
#4922 Post by RESET_9999 » Fri Apr 09, 2021 2:03 pm
dvidebaek wrote: Fri Apr 09, 2021 4:59 am
yes
mulucy
#4923 Post by mulucy » Fri Apr 09, 2021 3:19 pm
This is fantastic news! Might consider to get myself as well! Thank you for all the tests and contributions you have done so far!
A question about the Shield, is it confirmed that its playing the FEL DV with noise and Power Range ending credit scene tests?
chros
#4924 Post by chros » Fri Apr 09, 2021 3:32 pm
chros wrote: Thu Apr 08, 2021 11:25 pm Thanks for chiming in, it's good to talk to people who know their stuff :)
But I think this case is different: if I'm not mistaken, reset9999 has an LG C8, I have a B8 (apart form the peak nit capability they behave the same), these sets also do type 3 (not 2).
This is how it responds to various HDR10 metadata, so let's assume 1000 nits maxCLL.
I'll post similar graphs about 4 DoVi presets tomorrow, but even the most accurate Cinema preset brightens the image between 30%-70%, and that is clearly visible with normal content as well.
I only used SDR to DoVi upconversion with the Oppo, I observed 2 drawbacks (compared to 3dlut profiled SDR preset), hence I stopped using it:
- "shadow detail" is sometimes way more elevated almost at disturbing level (maybe it is related to the aformentioned brightening of middle range)
- colors get desaturated sometimes
I'm not sure what exactly the reason behind these, because most of the sime there's no issue at all.
I've added the B8 DoVi graphs into the post above.
#4925 Post by RESET_9999 » Fri Apr 09, 2021 4:04 pm
mulucy wrote: Fri Apr 09, 2021 3:19 pm A question about the Shield, is it confirmed that its playing the FEL DV with noise and Power Range ending credit scene tests?
The shield only supports MEL DV. it will play the FEL rip but will not decode the EL and will use only the dynamic metadata in RPU.
power rangers ending credits is dark grey and no FEL noise on the sample test file.
chros wrote: Fri Apr 09, 2021 3:32 pm
thank you
mulucy
#4926 Post by mulucy » Fri Apr 09, 2021 5:28 pm
RESET_9999 wrote: Fri Apr 09, 2021 4:04 pm
thank you
I appreciate it, thank you! I don't have any HD audio set up, will go with Google TV w Chromecast.
#4927 Post by RESET_9999 » Fri Apr 09, 2021 5:30 pm
so since my TV use maxcll (or MDL when no maxcll) and because maxcll is not very reliable(often incorrect), is it better to use madvr ''output in hdr'' with peak set to 700nits? what do you use ?
#4928 Post by SamuriHL » Fri Apr 09, 2021 11:18 pm
RESET_9999 wrote: Fri Apr 09, 2021 5:30 pm
On the C8 we're using 870 nits with madvr tone mapping. QuietVoid has posted some curves that work very well on our C8 with that NIT level.
DaMacFunkin
#4929 Post by DaMacFunkin » Sat Apr 10, 2021 6:40 am
mulucy wrote: Fri Apr 09, 2021 5:28 pm
thank you
Hi, remember the GTVwCC does not support frame rate matching.
XTrojan
#4930 Post by XTrojan » Sat Apr 10, 2021 10:19 am
Hi! does it support MKV DV? And is there any issues like the ugoos had?
mulucy
#4931 Post by mulucy » Sat Apr 10, 2021 12:42 pm
DaMacFunkin wrote: Sat Apr 10, 2021 6:40 am
thank you
It should not be a big deal since I never use that functionality with my Vizio TV. The ladder is doing pretty good job removing any judder. But wonder if Google is planning on releasing a software update soon to address it.
Another question, is everybody using Plex to play the FEL files on GTVwCC?
#4932 Post by RESET_9999 » Sat Apr 10, 2021 2:38 pm
XTrojan wrote: Sat Apr 10, 2021 10:19 am
yes, it supports DV MKV in PLEX, and from my quick testing session, it seems stable but I didn't watch a whole FEL movie yet. Lossy audio must be selected before playback otherwise the server complains about not being fast enough to convert truehd. At least lossy audio bitstreaming works. Also, this is a wifi device, so not sure how it handles the high-bitrate movies but should be fine thanks to the 5ghz. network info app showed 433 Mbps(which is obviously spec speed and not real-world speed).
mulucy wrote: Sat Apr 10, 2021 12:42 pm It should not be a big deal since I never use that functionality with my Vizio TV. The ladder is doing pretty good job removing any judder. But wonder if Google is planning on releasing a software update soon to address it.
it doesn't auto-match the frame rate but there is a 23.976 mode in display settings so there is no judder and playback is smooth on the app I tested(plex, iTunes, movies anywhere).
there's no 24fps mode so most of the original Netflix movies will stutter every 42sec in 23.976. 60hz will be fine.
DaMacFunkin
#4933 Post by DaMacFunkin » Sat Apr 10, 2021 4:48 pm
RESET_9999 wrote: Sat Apr 10, 2021 2:38 pm
yes, it supports DV MKV in PLEX, and from my quick testing session, it seems stable but I didn't watch a whole FEL movie yet. Lossy audio must be selected before playback otherwise the server complains about not being fast enough to convert truehd. At least lossy audio bitstreaming works. Also, this is a wifi device, so not sure how it handles the high-bitrate movies but should be fine thanks to the 5ghz. network info app showed 433 Mbps.
I had from day one and sold it after 4 weeks, wasn’t for me.
captainbrent
#4934 Post by captainbrent » Sat Apr 10, 2021 7:04 pm
RESET_9999 wrote: Sat Apr 10, 2021 2:38 pm Also, this is a wifi device, so not sure how it handles the high-bitrate movies but should be fine thanks to the 5ghz. network info app showed 433 Mbps(which is obviously spec speed and not real-world speed).
Apparently, there is an optional power adapter with built in ethernet capability! Unfortunately with only lossy audio, this is not for me.
#4935 Post by RESET_9999 » Sat Apr 10, 2021 8:03 pm
captainbrent wrote: Sat Apr 10, 2021 7:04 pm
great, just ordered one. thank's
