I'm new to this game so please forgive my ignorance.
I'm using an LG LG BE12LU30 (external USB BD) on a Mac Pro (Mac OS X 10.6.6). I've successfully ripped and encoded a few Blu-Rays over the last few days. However, I''m stuck on "Rome" Series 1 Episode 4 which the second episode on Disc 2.
Any help or advice would be greatly appreciated.
Here's the start and end of the log:
MakeMKV v1.6.3 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ05" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BE12LU30 4261" opened in OS access mode.
Evaluation version, 29 day(s) out of 30 remaining
File 00102.mpls was added as title #0
File 00005.mpls was added as title #1
File 00101.mpls was added as title #2
File 00103.mpls was added as title #3
File 00024.mpls was added as title #4
File 00025.mpls was added as title #5
File 00026.mpls was added as title #6
File 00027.mpls was added as title #7
Title #00003.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/internal_raid
1 titles saved
The source file '/BDMV/STREAM/00032.m2ts' is corrupt or invalid at offset 7867987968, attempting to work around
. [Many lines deleted']
The source file '/BDMV/STREAM/00032.m2ts' is corrupt or invalid at offset 7868049408, attempting to work around
Failed to save title 2 to file /Volumes/internal_raid/title02.mkv
0 titles saved, 1 failed
ROME Blu-Ray Rip Fail
chrispar
- Contact:
crowfax
Re: ROME Blu-Ray Rip Fail
Likely a damaged or badly pressed disc.
chrispar
- Contact:
Dirty disc, thanks. I cleaned it and then it ripped!
