Post by MartyMcNuts » Thu Mar 25, 2021 11:42 pm
trav06 wrote: Thu Mar 25, 2021 10:31 pm
MartyMcNuts wrote: Thu Mar 25, 2021 10:09 pm No problem. Also, I mentioned using 1.01-MK in step 2, which is ok, however, I just wanted to say that BP60NB10 1.00-MK is also good and is what I personally use.
I don't know enough about it, so unless there are advantages to 1.01 I'd likely just go with 1.00 as well. I was going on the often faulty assumption that newer revision = better.
Yes, in the case of drive firmware, newer is definitely not better!
dianagreece49
Post by dianagreece49 » Wed Mar 31, 2021 12:27 pm
see if you can fully pass the usb controller to the vm then it should work others have reported success like that see here: https://makemkv.com/forum/viewtopic.php ... =30#p70355
turok_t
Post by turok_t » Fri Apr 02, 2021 5:53 pm
MartyMcNuts wrote: Thu Mar 25, 2021 10:06 pm
turok_t wrote: Thu Mar 25, 2021 5:16 am Hello, I'm extremely new at did and I've been reading a lot of the posts in this thread. I'm simply looking for a 4k blu ray drive to rip my 4k movies to my PC and was thinking to get the ASUS BW-16D1HT. Do I simply flash it to MK 3.10? or will I need to use the SDFtool if the existing firmware on the drive is encrypted? I just finished reading all 56 pages of this thread! Sorry for the newb question, I just want to make sure I do this right so I don't brick my new drive! Thanks so much!
The ASUS doesn't have encrypted firmware, so yes simply flash 3.10-MK.
Thanks for the reply Marty! Do I just simply use the "ASUS_ODD_FW_Changer_(Modified)" that was posted on the first page, and flash it to "ASUS-BW-16D1HT-3.10-WM01601-211901041014" ?? It can't be that easy! or do I need the SDF tool as well in case if the version of the drive is 3.10+ ? Thanks!
Post by MartyMcNuts » Fri Apr 02, 2021 11:21 pm
turok_t wrote: Fri Apr 02, 2021 5:53 pm
The latest firmware on the ASUS BW-16D1HT is 3.10. Either flasher will work for this one.
hawk19x
Post by hawk19x » Mon Apr 05, 2021 12:07 am
hey Marty, just stopping by to say thanks for putting this together!
I just downgraded my external USB LG BP50NB40, then flashed it over to the hybrid BP60NB10 you provided and it’s worked like an absolute charm!
The first UHD disc I tried was Solo: A Star Wars Story.
I’ve since learned it’s apparently a bit notorious for not wanting to cooperate, which surprised me as it ripped just as simply as any other non-UHD disc I’ve done before flashing this fw.
awesome job, cheers again!
Post by MartyMcNuts » Mon Apr 05, 2021 1:20 am
hawk19x wrote: Mon Apr 05, 2021 12:07 am hey Marty, just stopping by to say thanks for putting this together!
No problem, glad it's working for you.
FYI, this is the older method. It still works but if you use the newer "SDFtool Flasher", the HBD firmware is not needed.
anfield
Post by anfield » Thu Apr 29, 2021 11:23 am
Hello Marty.
Please i need help to get my bricked Lg Bh16NS55 back to work.
it showd now Bh16NS40_boot.
You can help me ?
if i youse the asus lg flasher i get a updating failure #5.
and the sdf flasher 1.20 wont start.
Any Help.
Thanks a lot.
Post by MartyMcNuts » Fri Apr 30, 2021 12:25 am
anfield wrote: Thu Apr 29, 2021 11:23 am Hello Marty.
You can help me ?
Any Help.
Thanks a lot.
I assume you were previously able to rip UHD with this drive? What firmware was it on? What happened to the drive to go into boot mode?
Try using the original LG 1.05 flasher viewtopic.php?f=16&t=24443 to flash the drive to original BH16NS55 1.05 and hopefully it will no longer be in boot mode.
If this works, then use the SDFtool Flasher to flash the drive to a UHD capable firmware.
Step 1: Flash drive to WH16NS60 1.02 MK (with "enc?" checked). If you only use MakeMKV for ripping, stop here, otherwise proceed to step 2.
Step 2: Flash drive to DE BH16NS55 1.02 (no "enc?" this time)
anfield
Post by anfield » Tue May 04, 2021 2:33 pm
thanks for your Help.
But the LG Flasher not working.
I get an error : valid atapi device can not be found.
F/w model BD-Re BH16ns55.
I used this flasher to update the drive and now i on the drive shows bh16ns40 boot.
the sdf flasher 1.20 does not start if i click on start
Post by MartyMcNuts » Wed May 05, 2021 12:58 am
anfield wrote: Tue May 04, 2021 2:33 pm thanks for your Help.
You could try the old dosflash method. There are lots of threads/posts about it.
anfield
Post by anfield » Wed May 05, 2021 1:20 am
any help with the dosflash options are welcome.
Thanks anfield
Dosflash 2.0 says no no chipset found.
Not mtk vendor found etc.
So i give up and take the drive to the trash and buy an new one.
Thanks for Help.
mgutt
Post by mgutt » Wed May 05, 2021 2:18 pm
Maybe someone is interested:
Upgrade of my LG BH16NS55 through this USB adapter failed:
https://www.amazon.de/AD-U3SA-Adapter-F ... 01C8ZYV04/
This one (or SATA) worked:
https://www.amazon.de/IB-AC704-6G-SATA- ... 01DD9Z15I/
martinmcu
Post by martinmcu » Wed May 12, 2021 5:42 pm
My old BP50NB40 died. I bought a replacement, but am having difficulty flashing it. As best I can tell, this is the most recent set of instructions for this drive:
viewtopic.php?p=107174#p107174
trav06 wrote: Thu Mar 25, 2021 10:01 pm
MartyMcNuts wrote: Mon Mar 22, 2021 3:29 am
Step 1 is ok, but you can't use the ASUS flasher as your drive has encrypted firmware. Use the "SDFtool Flasher" with "enc?" checked.
Step 2 should be: Flash BP60NB10 1.01-MK from the MK/old folder using SDFtool Flasher with "enc?" unchecked. Don't use BP60NB10 1.02 as it's crap.
Done!
Thank you thank you thank you! Haven't gone through the steps yet, but this will save me a lot of trouble.
However, I am having difficulty with step 1. I only have Linux systems in the house, but it seems like I should be able to use the sdftool command line. Here is my drive info:
matt@superlappy: ~/uhdfw
[]$ sdftool -l
Found 1 drives(s)
00: dev_21:0, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIK06L1SD0537
[]$ sdftool -d /dev/sr0 --info
SDF.bin version: 0x007E
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:1.03
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:2C1A8405ECEF
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BUP3:HL-DT-ST:BD-RE BP50NB40  1.03:N000800:-
[]$ sdftool -d /dev/sr0 help
MTK19xx firmware module v1.22
Commands:
  dump [auto|full|user]
  Dumps firmware image
    dump full      - dumps full rom image (if not disabled in firmware)
    dump user      - dumps non-volatile user data
    dump auto      - dumps full image if possible, user data otherwise
  rawflash [<flag>,<flag=value>,...]
    Sends the image and flashing flags to drive
    for flashing in self-update mode
  flags:
    main           - flashes main firmware (this is the default)
    full           - flashes boot loader and main firmware (Caution!!!)
    de             - sets DE byte in image
    enc            - encrypts firmware before sending to drive
However, flashing fails:
[]$ sdftool -d /dev/sr0 rawflash enc -i HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin -v
Loaded SDF.bin version 0x7e
Reading input file HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
Current Drive ID: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIK06L1SD0537
DEBUG: Code 4280012805 at Mx=Q{%DdK23UWRSK}6/xi^l-6'?wWl*&:121264648
Command produced error code 0x8f1bd005
Am I missing something, or do I need to look into a Windows VM/finding a physical Windows box? Thanks,
Matt
liamtoh1
Post by liamtoh1 » Sun May 16, 2021 3:39 pm
This week I purchased an LG WH16NS40 from Amazon Warehouse (they accidentally send me LG WH14NS40 with a mfg date of Jan-2017). This drive came with 1.02 firmware which was able to decrypt and create BDMV and/or MKV using MakeMKV. However, it would give an error when creating ISO using ImgBurn saying the disc is copy protected. I tried to update the firmware with 2 other methods
1. Command line option using makemkvcon64.exe f --all-yes -d H: rawflash enc -i "C:\Program Files (x86)\MakeMKV\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin") and
2. SDF tool flasher.
Both options did not update the firmware.
I was about to open a message here when I happen to come across this thread. I was hesitant but gave this ASUS ODD FW changer a shot and voila.. it worked.
Thanks for this thread and helping me update my drive.
ASUS ODD FW Updated Screenshot 2021-05-16 111933.jpg (26.81 KiB) Viewed 42711 times
Post by MartyMcNuts » Mon May 17, 2021 3:01 am
liamtoh1 wrote: Sun May 16, 2021 3:39 pm This week I purchased an LG WH16NS40 from Amazon Warehouse (they accidentally send me LG WH14NS40 with a mfg date of Jan-2017). This drive came with 1.02 firmware which was able to decrypt and create BDMV and/or MKV using MakeMKV. However, it would give an error when creating ISO using ImgBurn saying the disc is copy protected. I tried to update the firmware with 2 other methods
The command line and SDFtool flasher didn't work for you because you had "enc"in the command. Your 1.02 firmware is not encrypted!!
