Revolution (tv series) Season 1 bluray
willman42
Post by willman42 » Fri Apr 02, 2021 1:39 am
Does anyone know the proper episode order for Revolution (the tv series) Season 1 on bluray? I can't play the disc on my Windows 10 PC without downloading .dll's from a Russian website with a history of certificate issues (vlc-bluray.whoknowsmy.name). Seriously, that's the only advice ever given for getting bluray to work on Windows 10, and literally nobody seems to have a problem trusting the site and the .dll's it provides... But whatever, I'm not using it.
If I could even get the exact runtimes of the episodes, that would help. Wikipedia doesn't list runtimes at all, and IMDB doesn't specify seconds, and it also appears inaccurate too. When playing after ripping, the episodes don't list the Director or Writer for each episode, which could have helped too.
I know the title order is not the episode order because the first episode of the series (differentiated by the lack of the series recurring intro) is title_03. Titles are listed 00 - 04.
Anyone have any idea?
Re: Revolution (tv series) Season 1 bluray
Post by Woodstock » Fri Apr 02, 2021 2:14 am
You can use the MakeMKV VLC integration to play the BDs in VLC.
Or, you can rip them all to MKVs, and then watch enough of each to verify the episode. I have had to do that with a lot of stuff, including many of the Star Trek: The Next Generation BDs.
preserve
Post by preserve » Sun Apr 04, 2021 2:17 am
I have this series... the UK release.
This series was released in many countries and there may be minor differences. Which release do you have?
Using: ASUS BW-16D1HT 3.00
jonarnold
Post by jonarnold » Thu Jan 06, 2022 11:47 pm
In case you didn't get this sorted out, here's what I had to do for Season 1 (sorted smallest filesize to largest):
what I thought I ripped -> what it actually was
S01E02 -> S01E03
S01E03 -> S01E02
S01E11 -> S01E09
S01E10 -> S01E11
S01E14 -> S01E13
S01E01 -> S01E05
S01E13 -> S01E14
S01E12 -> S01E16
S01E05 -> S01E04
S01E08 -> S01E07
S01E04 -> S01E01
S01E06 -> S01E10
S01E15 -> S01E12
S01E18 -> S01E20
S01E09 -> S01E06
S01E07 -> S01E08
S01E17 -> S01E15
S01E20 -> S01E18
S01E16 -> S01E17
S01E19 -> S01E19
Here's Season 2:
S02E10 -> S02E09
S02E12 -> S02E07
S02E11 -> S02E08
S02E08 -> S02E11
S02E14 -> S02E17
S02E18 -> S02E13
S02E21 -> S02E20
S02E13 -> S02E18
S02E03 -> S02E05
S02E20 -> S02E21
S02E16 -> S02E15
S02E19 -> S02E22
S02E09 -> S02E10
S02E15 -> S02E16
S02E06 -> S02E01
S02E22 -> S02E19
S02E07 -> S02E12
S02E01 -> S02E03
S02E17 -> S02E14
S02E02 -> S02E06
S02E04 -> S02E04
S02E05 -> S02E02
Only one episode in each season was correct. Filesize should correlate to length as long as your files were ripped with the same settings. I can give you lengths if you need them.
Ballesteros
Post by Ballesteros » Wed Jun 07, 2023 4:06 pm
Hi, if anyone has a list of the episode durations or file sizes for Revolution blu-ray seasons 1 + 2, that would be much appreciated. Even better if it's the UK release.
Only being able to find episode durations rounded to minutes, not seconds, I really struggled to id the episodes on each disc for this one without major spoilers.
TIA
