logfile
fpefpe
logfile
Post by fpefpe »
Hello --- where is the location of the "logfile"
Re: logfile
Post by d00zah »
fpefpe wrote: Thu Apr 01, 2021 2:23 am Hello --- where is the location of the "logfile"
When you enable "log debug messages" on the 'General' preferences tab & restart MakeMKV when prompted, the path is reported in the output pane, below the MakeMKV version... i.e. :
MakeMKV v1.16.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log.txt
fpefpe
Re: logfile
Post by fpefpe »
thx for the info
Re: logfile
Post by d00zah »
fpefpe wrote: Thu Apr 01, 2021 12:41 pm thx for the info
You're welcome.
Just to follow up, you can manually capture the content of the Output (or Info) pane any time using the context menu... right-click on the output pane & select "Select all", right-click again & select "Copy". Paste text wherever. This can avoid the "clutter" of debug msgs when only the general output will suffice.
