Regsitry settings for Speed
jwaltrip4
Post by jwaltrip4 »
I have looked at the examples, and none of them show and actual picture if the settings...
HKEY_CURRENT_USER\Software\MakeMKV is the reg key
the key is speed_HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLNK369253
What I am not sure of is the value.... the examples show the value in quotes:
"D1=99;D2=99;D1=-,D2=-;U1=-;U2=-;U3=-"
Is that what the value should be... quotes and all.... or should it be without quotes.
Re: Regsitry settings for Speed
Post by d00zah »
jwaltrip4 wrote: Thu Apr 01, 2021 2:20 am I have looked at the examples, and none of them show and actual picture if the settings...
It depends on where you are looking.
Using a .reg file to import settings, quotes are required:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\MakeMKV]
"speed_HL-DT-ST_BD-RE__WH16NS40_1.03_211711211653_K9xxxxxxxxx"="0=99"
If editing via regedit, no quotes:
regedit (Small).jpg (27.46 KiB) Viewed 6423 times
