LG WH16NS40
horrorfiend666
LG WH16NS40
#1 Post by horrorfiend666 » Mon Mar 22, 2021 10:09 pm
Just picked it up and the firmware is 1.05 do I need to do anything to be able to read and write uhd discs
Re: LG WH16NS40
#2 Post by Billycar11 » Mon Mar 22, 2021 10:18 pm
horrorfiend666 wrote: Mon Mar 22, 2021 10:09 pm Just picked it up and the firmware is 1.05 do I need to do anything to be able to read and write uhd discs
i wouldn't bother with the writing get some hard drives.
email me if you want an automated self flash kit
horrorfiend666
Re: LG WH16NS40
#3 Post by horrorfiend666 » Mon Mar 22, 2021 11:09 pm
Flashed successfully to firmware 1.03 confirmed UHD can be played back successfully
fangelov
Re: LG WH16NS40
#4 Post by fangelov » Thu Mar 25, 2021 7:15 pm
What procedure did you use? I have the same drive with 1.05. Thanks!
Scuph
Re: LG WH16NS40
#5 Post by Scuph » Wed Mar 31, 2021 6:19 pm
I just picked one up and am trying to figure out what firmware to flash to it. I have been following this guide: viewtopic.php?t=19928 But since that is talking about a different drive I am a bit lost on which firmware to actually flash to it. Thank you for any help.
Re: LG WH16NS40
#6 Post by Billycar11 » Wed Mar 31, 2021 7:59 pm
Scuph wrote: Wed Mar 31, 2021 6:19 pm I just picked one up and am trying to figure out what firmware to flash to it. I have been following this guide: viewtopic.php?t=19928 But since that is talking about a different drive I am a bit lost on which firmware to actually flash to it. Thank you for any help.
Please don't follow that guide it has unnecessary steps.
Follow mine linked below or email me for an automated flasher
Re: LG WH16NS40
#7 Post by d00zah » Wed Mar 31, 2021 8:05 pm
Billycar11 goes to great lengths to keep the Ultimate UHD Drives Flashing Guide Updated 2021 up to date with all the current wisdom. The guide you are following is older & may miss some important details.
See section Recommended Firmware to flash for MakeMKV: to determine FW you want.
When you read further to section Newer OEM Firmwares and encrypted:, you may find that your current FW (what the drive came with.. v1.05?) is encrypted, requiring you to use the SDFtool Flasher with 'enc' checked for the 1st flash. The procedure in the 1st post includes download links & procedure.
Scuph
Re: LG WH16NS40
#8 Post by Scuph » Wed Mar 31, 2021 8:51 pm
Billycar11 wrote: Wed Mar 31, 2021 7:59 pm
I was able to get it working by following your guide Billycar11, thank you for the write up.
