LibMMBD not working on 1.16.3
gindeno
Post by gindeno »
LibMMBD is working on 1.15.4 in VLC and MPV.
After updating to 1.16.4 (and updating the libmmbd.dll installation) both VLC and mpv fail.
[bd] AACS error: opening or reading of AACS files failed
No protocol handler found to open URL br://14/D:
The protocol is either unsupported, or was disabled at compile-time.
I have ensured it is registered and can manually rip discs.
Downgrading to 1.15.4 (and dlls) fixes it.
OS: Windows 10
MPV 0.33
Thanks.
fscii
Re: LibMMBD not working on 1.16.3
Post by fscii »
I too cannot get LibMMBD working.
MakeMKV: 1.16.3 and 1.16.4 (tried both)
VLC: 3.0.16
OS: Windows 10 Pro, v 2004, OS build: 19041.1083
BD: BU40N flashed to 1.03
Manual rips work fine.
If I try to play a blu-ray in VLC without LibMMBD, I get the expected error:
Blu-ray error: This Blu-ray Disc needs a library for AACS decoding, and your system does not have it.
Then following these instructions I enable LibMMBD:
http://www.makemkv.com/libmmbd/
I have tried system wide and VLC specific, in both cases I get the following error from VLC:
Blu-ray error:  Blu-ray Disc is corrupted.
Since the error message changed in VLC once I enabled LibMMBD, I can see it has an effect on VLC, just not the desired effect.
VLC log is the same with and without LibMMBD:
-- logger module started --
main: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
main: playlist is empty
libbluray: First play: 1, Top menu: 1
HDMV Titles: 17, BD-J Titles: 3, Other: 0
-- logger module stopped --
TIA for help
Buy a makemkv key and it will work it does not work with the trial version
fscii
Post by fscii »
Billycar11 wrote: Fri Jul 09, 2021 9:51 pm Buy a makemkv key and it will work it does not work with the trial version
That's an interesting fact that would've been helpful for the author to include on http://www.makemkv.com/libmmbd/ -- or grey the options out in unregistered version with a tooltip stating so.
Anyway, thank you for the information and saving me from banging my head against a wall any longer!
