Error messages but still rips
Toddn149
Post by Toddn149 »
I’m trying to rip dvds, Blu-ray’s, and 4K discs and I’ve been successful but getting the attached error message. While I’m fine since it works, I’m getting slow read speeds and taking about 30 min for a DVD, and a 4K about 3-5 hrs depending on size.
Re: Error messages but still rips
There are parts of your disk that the drive cannot read, which lead to the problem with "scrambled sectors". Fortunately, they are not part of the video itself, or saving the title would fail.
Cleaning the disks in question would be the first step, after enabling debug logging in your preferences.
You can copy/paste text from the info window, rather than taking pictures of the screen.
Toddn149
Post by Toddn149 »
Thanks for getting back to me. The discs outside the DVDs are brand new, the DVDs are clean but not perfect. I’ve tried 2 4K discs and same errors and 10 DVDs.
The fact I’m getting clean rips, I guess is good, but would this contribute to slower read/ripping speeds as you see? I can do the log cut and paste if you need to see that.
